Author Topic: Aimtrak sensor bar position  (Read 2974 times)
Valken
  • Last login:March 05, 2025, 06:05:48 pm
« on: September 12, 2010, 05:46:01 pm »
Hi mates, I've a question for you:
Is it possible to mount aimtrak sensor bar under the monitor instead of above it as reported in the user manual?
I'm not an aimtrak owner but id'd like to buy one and I'm wondering if it could be a good idea to mount the sensor bar (with a shell) under the control panel of my cab (see the attached picture) and take it out and lean it on the cp (that is fastened with velcro and very easy to open) only when I want to play lightgun-games.
Uploaded with ImageShack.us
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
Re: Aimtrak sensor bar position
« Reply #1 on: September 12, 2010, 06:32:46 pm »
My understanding was that the bar wants to be as close to the top of your screen as possible so once they release the bar with cover, you could easily velcro just above the screen. I'm in a similar boat. I have a greylite glass bezel so it has to look nice and can't be hidden behind it
Valken
« Reply #2 on: September 14, 2010, 03:39:48 am »
Yo'ure right, but if I fasten the sensor bar with velcro above the monitor, I have to drill the tinted plexiglass (or the marquee retainer) to let the usb cord enter into the cab.
I'm just wondering if the sensor bar does work under the monitor (like the wii s.b. does) and, if the answer is no, if ther's a way to tweak the config software or the firmware, to let it work correctrly this way...
