Author Topic: acrylic thickness for a CP top  (Read 1929 times)
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« on: September 10, 2010, 05:38:21 pm »
I was going to use some .220" thick acrylic for hte top of my CP.  Nice and heavy so it will not flex.
As it turns out I think I might need to do something thinner.  has anyone used the .097" thick acryllic on their CP?  And held it down with jsut hte buttons?  If so, do the edges that are not near the buttons stay flush with the edge (assuming t-molding is on the edge)?
MY FIRST BUILD:
severdhed
  • RIP Dinosaur Hippo
Re: acrylic thickness for a CP top
« Reply #1 on: September 10, 2010, 06:19:24 pm »
i'm not sure what the exact thickness of the plexiglass i used on my panel, it was just under 1/8" thick, on top of my 5/8" MDF.  it is held down with nothing but the buttons.  the Tmolding covers the edges of the plexi and it stays in place very well.  if you are going to have the plexi sit above the tmolding, then you may need screws/bolts to hold it down at the edges
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« Reply #2 on: September 10, 2010, 10:21:01 pm »
Mine's also 1/8 thick on a 5/8 panel. Also held with buttons. Thin artwork that floats can ripple a little. Mine did until I replaced it with art on .050 poly. Rigid and nay unripplable.
ragnar
« Reply #3 on: September 10, 2010, 11:05:37 pm »
Sounds like the thinner stuff will work.  I'll be buying the new stuff soon.
MY FIRST BUILD:
