Author Topic: aunt annis projects  (Read 16931 times)
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: aunt annis projects
« Reply #40 on: June 02, 2011, 02:27:09 pm »
i took advantage of the premade rotating mechanism , but i still think its nonsens to play 32 inch vertical . the screensize set to horizontal is more than enough on this short distance. btw. a 4:3 shooter on a 16:9 screen with black bars on top and bottom wont top a 25 inch 4:3 crt .
« Last Edit: June 02, 2011, 02:31:12 pm by apfelanni »
« Reply #41 on: June 02, 2011, 02:28:49 pm »
Well, you still did a great job with it!
tapule
  • Last login:July 19, 2018, 04:54:54 am
    • Gelide FrontEnd for Linux
« Reply #42 on: June 02, 2011, 02:43:05 pm »
Apfelanni great job!!
You have a really nice collection of arcade cabinets
Greetings
Gelide FrontEnd for Linux http://gelide.sf.net
apfelanni
« Reply #43 on: June 02, 2011, 03:13:02 pm »
my lcd project took a little longer than expected , coz i had to finish the paintjob on another rustbucket first. usually we dont experience storms or tornados here in central europe like you us-guys , but after 2 weeks my selfmade tent couldnt take any more beating . so i decided to delay the lcd project for some time .
about 1 year ago i purchased a namco 19 on ebay ger for around 1xx bucks . it was in rough shape , still working with some monitor problems ( burns , hor coil damaged etc.) , rusty , handpainted monitortop . i dumped it it in my garage for some time , but while its not getting better in years i deciced to refurb it now . after dismantling and cleaning it got spraypainted in black and orange. my first thought was candywhite + red or blue , but i had about 1 litre satin black left from the felixcab . so i ordered 0,25 litre for the orange cabinet parts . its called " jägermeister " orange , no ral or us standard colour . the sticks were ok , only the buttons and balls had to be replaced. the mitsubishi tube / nanao chassis was replaced by a grundig tv set with philips tube . it doesnt´fit in 100 % , coz its 1 inch smaller, so i build some cheap mounting frame . the idea was to use a mak with jamma harness to play jamma pcbs , but in the end i decided to mame it and take on of my other cabinets for the jamma stuff. i ordered an ipac controller and the sanwa stuff from arcadeshop.de and took a dell optiplex p4 out of another mame cab and soldered a mamescart cable ( quality one with coax rgb wires and additional audio connectors ) from roline . the 5/12 volt connection to scart pin 8 wasnt necessary , coz the screen autostarts with av rgb when powerd on.
apfelanni
« Reply #44 on: June 02, 2011, 03:14:29 pm »
more pics ..
apfelanni
« Reply #45 on: June 02, 2011, 03:15:40 pm »
apfelanni
« Reply #46 on: June 02, 2011, 03:16:51 pm »
BobA
  • What Me Worry?
« Reply #47 on: June 02, 2011, 03:19:52 pm »
Nice looking collection of cabs.  Some very innovative designs.  :applaud: :applaud:
apfelanni
« Reply #48 on: June 02, 2011, 03:24:36 pm »
i had to move the little fellas a little closer , but finally it fits in. unfortunately my arcade apartment cannot compete with the peter hirschberg shed . lets say its getting crowded here ..
next thing i like to start is a mvs 13-2 repro or a 70 % shrink of the phantastic mission control cabinet.
« Last Edit: June 02, 2011, 03:34:01 pm by apfelanni »
lettuce
  • Make It So!
« Reply #49 on: July 07, 2012, 10:23:49 am »
apfelanni, do you have any plans for your lowboy camo cab??, i want to make a similar cab but to house a 25" monitor, what size monitor is housed inside your cab?
apfelanni
« Reply #50 on: July 08, 2012, 07:00:11 am »
my 3 lowboystyle minis are housing a 13 inch vertical , a 20 inch and a 21 inch horizontal screen . all 3 of them are very small , around 5x cm wide , 6x deep and 1 m high. u can adapt the lowboy concept for a 25 inch crt without probs , check hardmvs.com / pics / pacific . if its of some use i can upload some more pics . u may also search for lowboy arcade here in forum or google images.
lettuce
  • Make It So!
« Reply #51 on: July 08, 2012, 07:24:48 am »
Thanks for the info. If you could upload some more pics of of your lowboys that would be great, im mainly interested in your red neo-geo lowboy
« Last Edit: July 08, 2012, 07:27:38 am by lettuce »
