Author Topic: Shelled MA... have an issue.  (Read 4174 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« on: August 15, 2010, 08:17:44 pm »
So my new cab is all done (pedestal style) will post pics soon... however, after setting up the computer to hide windows, shelling MA... the batch file in my start up folder to run LED Blinky gets bypassed. How can I fix this?
deepblue
  • Last login:December 12, 2018, 07:39:28 pm
  • Billy vs. Steve
Re: Shelled MA... have an issue.
« Reply #1 on: August 16, 2010, 12:15:13 pm »
CTRL-P for Prefs, go to first tab and look at the bottom where LED Blinky info goes.
Arzoo has detailed instructions in his PDF for LEDBlinky that explains precisely how to setup LEDBlinky to work with MA.
Ditch the Batch Files, etc.
methodical
« Reply #2 on: August 17, 2010, 10:49:46 am »
Yeah I saw that but it seemed to run different animations/button settings for each emulator, etc. Wanted just one animation to start playing when it turns on and not stop...
Under options there's a way to run a program at start, that worked.
deepblue
  • Billy vs. Steve
« Reply #3 on: August 17, 2010, 10:53:24 am »
Just define a single scheme for FE Active and that should do it for you. You might run into trouble using the batch file approach, plus won't that make the animation continue while you're playing a game?
  • Last login:July 11, 2025, 09:17:44 am
« Reply #4 on: August 22, 2010, 09:33:05 pm »
Yes, running a program at start in another approach to solve your problem.  Especially if you want it to retain your configuration like worked before you shelled it.
D
