Author Topic: Way to remove the ROM nag screen?  (Read 4879 times)
« on: August 11, 2010, 03:53:30 pm »
When I play any game on MAMEUI 0.139 through Maximus Arcade (thought I'd mention both, although I figure the issue is with one of them) I receive a nag screen confirming the legality of playing said game.  Basically, it says, "Key in OK or use your joystick to go left then right" and sometimes, it also confirms video and/or audio issues, with another "OK/leftyrighty" screen.  Is there any way of turning these off?  It's a major bummer to have them there.
Thanks, in advance!
jimmy2x2x
Re: Way to remove the ROM nag screen?
« Reply #1 on: August 11, 2010, 04:02:22 pm »
have a look here:
http://forum.arcadecontrols.com/index.php?topic=64298.0
Basically you need to compile a new version of mame, it looks complex but isnt really
Just follow the steps carefully
This has the added advantage of saving hiscores for lots of games as well as removing the nag screens
« Reply #2 on: August 11, 2010, 04:09:48 pm »
have a look here:
http://forum.arcadecontrols.com/index.php?topic=64298.0  Basically you need to compile a new version of mame, it looks complex but isnt really
Asked, and answered.  Thank you so much!
« Reply #3 on: August 12, 2010, 02:02:20 pm »
Just wanted to pop back in here and confirm that everything worked perfectly.
I downloaded the .TXT file for MAME 0.139 from the link, renamed it to .DIFF, downloaded the Headsoft MAME Compiler program, applied the DIFF Update, compiled my own version of MAME, ran it with -cc to configure the MAME.INI file, and finally edited the MAME.INI file to add the three lines required to remove the nag screens.
Yes, it's a run-on sentence, but it makes the point.  It was easy, and I thank you for the help!
