Author Topic: Vertical Games Monitor Resolution Question  (Read 1487 times)
borals
  • Last login:March 07, 2020, 05:51:14 am
« on: August 05, 2010, 08:07:20 pm »
Howdy,
I have a question about some vertical game's res, more specifically the Psikyo (http://en.wikipedia.org/wiki/Psikyo) games res.
Most vertical games I have seen are basically a 4:3 monitor rotated on it's end, but the Psikyo shooters seem to have almost a widescreen resolution rotated on it's end.
Am I missing something here, as on KLOV it just states the Arcade Monitor Type as "standard" same as Donkey Kong for example.
I have a cab that is using a CRT computer monitor, and when I play DK for example it letter box's the side (no stretch on), but when I play one of the Psikyo games it letter box's the side more.
I have access to some cheap LCD's so I was considering making a shooter cab, and the Psikyo games are some of my fav, I just wanted to know if I should get a widescreen LCD or standard.
Sorry if that wasn't articulated very well, I;m at work, to I was rushing!
Any clarification appreciated, cheers.
« Last Edit: August 05, 2010, 08:13:02 pm by borals »
jimmy2x2x
Re: Vertical Games Monitor Resolution Question
« Reply #1 on: August 05, 2010, 08:27:37 pm »
As far as I am aware, all Psikyo games are in 4:3 ratio - I play them all the time on a rotated vertical (4:3) monitor - they look perfect to me.
You may get slight borders on some of the games, but if you got a widescreen monitor and rotated that, you would have larger borders (providing you keep the aspect ratio)
