Author Topic: Questions about spinners, and suppliers in the UK  (Read 6412 times)
jimmy2x2x
« on: August 02, 2010, 04:55:45 pm »
What to look for in a spinner? are the all similar or worlds apart?
What is the Seimitsu LS-29 like, can it be wired up to a PC?
Are there any UK based suppliers?
Besides spinner based games like arkanoid and tempest, what other games can make use of them - driving games maybe?
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Questions about spinners, and suppliers in the UK
« Reply #1 on: August 02, 2010, 07:43:15 pm »
I can vouch for the Spintrak from Ultimarc. You can hook it up to your minipac or buy it with a USB adaptor.
What to look for... it depends on personal preference (and the game itself) but a flyweight gives a good feel and plenty of spin.
I personally couldn't get on with it for driving games, but again that's personal preference.
Either way it's a great addition to a panel.
http://www.ultimarc.com/SpinTrak.html
SammyWI
« Reply #2 on: August 02, 2010, 07:51:15 pm »
+1 for Ultimarc.  I have two Spintracs.  Great product and service.
You can set up a spinner for left/right in games like Asteroids / Ripoff.  Not traditional, but fun for a change of pace.
jimmy2x2x
« Reply #3 on: August 02, 2010, 08:05:29 pm »
They do look very well made and very compact - not much bigger than a happ button really
So I would need the spinner body, flyweight (which one?) and knob (again not sure which!)
Would you recommend the USB interface?
SammyWI
« Reply #4 on: August 02, 2010, 09:08:22 pm »
Mine are both USB with the small flywheel and work well.  Knob is kind of personal preference but I kind of prefer the small one with the rubber grips slightly over the large knob on my other one.
Franco B
« Reply #5 on: August 03, 2010, 01:17:35 pm »
I may be selling my new in bag Turbo Twist 2 spinner, mini racer wheel and custom made Space Invaders spinner top if you are interested.
I'll dig it out later and get some pics etc.
Blanka
« Reply #6 on: August 03, 2010, 01:36:44 pm »
+1 for the Spintrack, I like it with the big weight, but for the knobs, I cross the atlantic. I love GGG's knobs better than Andy's.
jimmy2x2x
« Reply #7 on: August 03, 2010, 01:48:38 pm »
Sure thing franco, let me have a look when you are ready
Franco B
« Reply #8 on: August 04, 2010, 06:30:48 am »
Pics as promised:
Everything is new and not never installed/used. I bought it for my cocktail project but it went the way of the dinosaurs.
Consists of spinner, USB interface, USB cable, 5" mini racer wheel and custom Space Invaders spinner top.
The spinner top is CNC made from stainless steel with a genuine carbon fibre insert and a stainless steel laser turret. There are grooves around the outside to hold two rubber o-rings. The grub screw to attatch the spinner top to the shaft is hidden under one of the o-rings.
Price is £70 + shipping.
jimmy2x2x
« Reply #9 on: August 04, 2010, 10:45:50 am »
That looks like a neat setup Franco, but I don't think its right for me.
I wouldn't use the steering wheel and I think I would prefer a flyweight from the comments I've read.
Thanks for the kind offer Franco, I'm sure you won't have any problem selling that setup
Franco B
« Reply #10 on: August 04, 2010, 11:28:46 am »
The spinner top in its self is a flyweight ;)
No worries though, thanks for letting me know. I may as well stick it in BST now I have it all together.
RandyT
  • Last login:Today at 09:27:55 am
    • GroovyGameGear.com
« Reply #11 on: August 04, 2010, 11:59:51 am »
Heh.  I was going to say that too.  The ultimate in compact spinner arrangements include a heavy knob that acts as a flywheel.  Big, below the panel weights are unnecessary, and can actually hinder control in a number of games.  Too much momentum equals easy positional overshoot and slower initial movement due to the greater moment of inertia.
RandyT
« Last Edit: August 04, 2010, 12:02:11 pm by RandyT »
jimmy2x2x
« Reply #12 on: August 04, 2010, 12:28:59 pm »
My mistake, I thought the 'Energy Storage Cylinder' was the counter weight flyweight for these spinners
Ginsu Victim
  • Comanche, OK -- USA
« Reply #13 on: August 04, 2010, 12:56:27 pm »
Same here.
Hey Randy, what does it do?
RandyT
« Reply #14 on: August 04, 2010, 01:25:44 pm »
If you have a heavy enough knob, the ESC becomes extraneous.  Some who like a heavy feel to their spinner may opt for both, but there are disadvantages to too much flywheel weight on a spinner.  The one Franco made looks like it is plenty heavy enough to negate the need for a flywheel.
Also keep in mind that the ESC is very intentionally not overly large or heavy.  It has been tuned to provide a balanced feel for all games, and designed to fit through a button hole so it doesn't need to be removed to install the spinner.
RandyT
SammyWI
« Reply #15 on: August 04, 2010, 07:59:32 pm »
A spinner's feel would be a combination of the knob and any weight added on the shaft below the panel.  It depends on the feel you want and what the knob you prefer is like.  A larger knob of a heavier material will give a long spin all by itself with no extra flywheel.  But longer spin is not necessarily the best thing.  Different games had different feeling spinners.  So there is a lot of personal preference there.  I like a medium feel because I tend to play a wide range of spinner games.
I gotta say: that SI spinner looks very sweet.
Blanka
« Reply #16 on: August 05, 2010, 04:21:43 am »
It also depends on knob material. With an aluminium knob, I like a fly weight, but with stainless, you have 3 times as much mass on the knob already.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #17 on: August 05, 2010, 08:05:41 pm »
That's what she said.
