Author Topic: D9200 yellow tint out of nowhere - crap!! please help!  (Read 2895 times)
zmartin34
  • Last login:December 26, 2011, 09:22:42 pm
« on: August 02, 2010, 12:06:53 pm »
Hi folks! My D9200 in my MAME cab all of a sudden developed a nasty yellow tint to it.  ??? I've had this monitor for 2 years with no probs but all of a sudden when I turned it on this morning everything had a yellowish tint. No other disfigurement to the picture at all; everything just looked too yellow!
Most likely my ArcadeVGA or the monitor?
Can someone please advise me on this?
Thanks very much to anyone!!!!
MonMotha
Re: D9200 yellow tint out of nowhere - crap!! please help!
« Reply #1 on: August 02, 2010, 12:16:47 pm »
Feed it a black screen (just call up MS Paint or something similar and bucket fill it with black if that's the best you can do).  Do you have black or some other color where there should be black?
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #2 on: August 02, 2010, 01:19:02 pm »
I had a K7400 built Jan 2004 that exhibited the same type of problem. Turned out to be the power transistors on the neckboard for the blue component. Throw some color bars up and see if it's not missing.
grantspain
« Reply #3 on: August 02, 2010, 01:40:25 pm »
you can also access colours in the osd menu,sometimes these digital chassis get a static spike which can send colours or other adjustments a little crazy
MonMotha
« Reply #4 on: August 02, 2010, 02:05:24 pm »
Actually, that's true.  The D9xxx series is famous for EEPROM corruption.  You may be lucky and just need to re-set some things (possibly in the "factory" menu, which I don't know how to enter off the top of my head, but check the user menu first).  Color bars would be essential for adjusting things back.
zmartin34
« Reply #5 on: August 02, 2010, 03:43:32 pm »
thank you I will do this and check back...
zmartin34
« Reply #6 on: August 02, 2010, 03:45:10 pm »
Thanks but how do I put up color bars? I have a home theater disc that will surely have the pattern but I don't think my MAME PC has a DVD drive. Is there a way to put up bars with a menu?
Finally what do you mean when you state 'see if its not missing?'
zmartin34
« Reply #7 on: August 02, 2010, 03:46:10 pm »
Thanks; this I get lol just screw with the color setting within the OSD and see if I can correct it that way; will do...
zmartin34
« Reply #8 on: August 02, 2010, 03:47:12 pm »
Thanks Mon; I'm not familiar with the factory menu though; how do I access it?
MonMotha
« Reply #9 on: August 02, 2010, 03:51:44 pm »
I don't remember off the top of my head.  You don't want to mess around in it unless you have to.  It's intended for factory setting and service technicians only, but if the monitor has "lost its mind", then some of those settings may be wrong.  You'll want to figure out what the problem is and if it is correctable from the user (normal) menu, first.
newmanfamilyvlogs
« Reply #10 on: August 02, 2010, 03:52:33 pm »
If you're running mame on the computer hooked to it, many arcade games will produce various test patterns in the service menu.
zmartin34
« Reply #11 on: August 02, 2010, 04:42:01 pm »
Hi all things are well; for some reason the color push was completely screwed! A simple access of the menu and I was able to rectify it. This has never happened that's why I assumed the worst lol
Thanks to all for the help!!!  :applaud:
