Author Topic: Other emulators in MAMEWAH  (Read 2414 times)
pointdablame
« on: August 05, 2003, 03:02:05 pm »
I've been trying to get other emus to work in MAMEWAH, and I am having no luck at all. I was following the stuff on stuzza's site for settings, and I know my paths are correct. I've tried with FCE Ultra and VBA so far, and they both come up with an error when I try to refresh the game list. Something like "trouble opening -listinfo" or some such.
Can someone please help me? I have no idea what I'm doing and would really love to get my other emus running through MAMEWAH (ideally NES, SNES, Genesis, Atari2600, GBA)  I know people can do it, so if you wouldn't mind helping me out, I'd appreciate it.
first off your and idiot
Cave
  • Last login:June 07, 2009, 10:27:58 am
Re:Other emulators in MAMEWAH
« Reply #1 on: August 05, 2003, 07:26:15 pm »
have you made sure that the "list generation method" is set to rom folder only, you can change this when mamewah is running if you go through the menus.
pointdablame
« Reply #2 on: August 05, 2003, 08:19:00 pm »
I'm not sure if I did that or not. I'll have to check when I get out of work. Thanks for your help.
Any other settings I could be forgetting?
And while I'm at it, will any of the following emulators just NOT work well with MAMEWAH. If not, I could prolly save myself some frustration and just find another emu.
zSNES
FCE Ultra
Visual Boy Advance
Gens
z26
Thanks for any help you can give me.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #3 on: August 05, 2003, 08:44:50 pm »
I run all of those emulators through Mamewah without a problem.  As Cave said, it sounds like your list generation method is wrong.  Also ensure you have show dos box set to yes - this seems to solve a lot of issues :)
« Reply #4 on: August 06, 2003, 07:03:31 am »
Correct :)
Although you do not need to 'Show DOS Box' for (Windows) MAME, or ZSNES.  Gens requires it, I'm not sure about the others mentioned...
Isometric Bacon
  • Last login:February 28, 2014, 08:53:57 pm
  • Lets get dangerous!
« Reply #5 on: August 06, 2003, 09:27:21 am »
For some reason I get an odd error with Visual Boy Advance too.
When I try to load a game, it comes up with a message saying that it is an unsupported filetype... even though it works perfectly through Visual boy itself... I would say it because it isn't sending the file extension... (it says unsupported rom e.g. C:\GBA\ROMS\SONIC without the .gba extention..)  but i've filled with the Mamewah settings and I have "send file extension" and everything else set to yes.
Any help?  :(
« Reply #6 on: August 06, 2003, 09:55:31 am »
Any help?  :(
Open the file 'debug.log' inside the MAMEWAH folder to see what MAMEWAH is doing (after running a game)...
Try running the emu from a commandline also, you can then try to 'match up' what you did with what MAMEWAH does.
Isometric Bacon
« Reply #7 on: August 07, 2003, 04:29:40 am »
Any help?  :(
Thanks for the help. According to the log it "seems" to be doing everything okay... but it still has the problem.
"C:\MAMEWAH\GBA\VISUAL~1.EXE C:\MAMEWAH\GBA\ROMS\SONIC ADVANCE.GBA
" Is what comes up in the log.
Also, how do you mean running it via command line? I understand what a command line is, (e,g. Mame.exe -noborder) or something along those lines, but I don't understand what you mean in this context...
Do you mean make a batch file? or somehow put an extra command line on the end of the emulator executable?
stuzza
    • ScreenshotArchive
« Reply #8 on: August 07, 2003, 05:41:10 am »
Are you running Windows 98??  If so, try setting "Use Long filenames" to No (False in the cfg file).
From your line:
It looks like you are using long filenames ie, the "SONIC ADVANCE.GBA" is in long format, not dos 8.3 style.
« Reply #9 on: August 07, 2003, 07:36:22 am »
What I meant was, go into MS-DOS Prompt (Win98) or Command Prompt (2k/XP).  It is usually within Start > Programs > Accessories.
You need to run the emulator directly, from a commandline rather than MAMEWAH...
I won't bother to explain further because I think in this case Stuzza is right - set 'Use Long Filenames' to 'No'.  I just looked back at your earlier post and you said VBA was saying 'C:\GBA\ROMS\SONIC' not a valid rom or whatever - it is cutting off the part after the space.
Isometric Bacon
« Reply #10 on: August 07, 2003, 09:16:27 am »
Okay, that worked a treat. Thankyou very much :) I really appreciate all the stuff you guys do for the community.
Also, is there anyway I can remove the file bar on Visual boy Advance, and also allow it to escape on pushing exit? I've heard of wrappers, where could I find one of these?
Thanks for your time.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #11 on: August 07, 2003, 09:30:19 am »
Have you tried Girder? I think it can be used for what you want...and much more. Find it here:
http://www.girder.nl/
Hope this helps!
All Your Base Are Belong To Us!
