Author Topic: Quick question-T-Stik mounting position  (Read 2768 times)
FISHERMAN
  • Last login:October 28, 2021, 11:36:46 am
« on: July 30, 2010, 07:07:28 am »
I am constructing my bartop cab and i have some questions.
Is there any problem mounting the joystick horizontaly or
vertically? Is there any difference apart from the space
needed on th control panel??
Horizontal
Vertical
Kman-Sweden
  • Up the Irons!
Re: Quick question-T-Stik mounting position
« Reply #1 on: July 30, 2010, 07:43:00 am »
Nonewhatsoever. It's up to how you wrie them up... up will be up, down will be down and so on...
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
« Reply #2 on: July 30, 2010, 12:03:20 pm »
as kman said above, it doesnt matter at all what way you mount them  ;)
because its the wiring which will decide what way is up and which way is down.
personally , i would mount them in the vertical position, as this will give you more room to manovure within
the control panel itself and will allow for a tighter fit of all hardware overall , i.e - you can mount your buttons closer
to the joystick when its in the vertical position .
its up to you to decide , whatever you feel happy with at the end of the day is what you should opt for ,
but i would really let the dimensions of the control panel decide which way to mount the hardware if it comes to space restrictions  ;D
I may be a jackass , but im no fool !
FISHERMAN
« Reply #3 on: July 30, 2010, 06:03:49 pm »
thank you very much for your prompt answers... ;D
