Author Topic: Kortek KT-2938F  (Read 4507 times)
southmonitor
  • Last login:September 18, 2010, 08:10:10 pm
Kortek KT-2938F
« on: July 29, 2010, 07:13:44 pm »
Hi:
Does anyone knows wher I can find the Schematic or Service Manual for the KORTEK KT-2938F. I have one with a blown HOT (J6820) and the IRF840A. I replaced them and now I have HV; but only a Vertical line in the center of the screen (No Horizontal Deflection). Most components are good when tested without power. I need the schematic to chase the problem.
Thanks.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Kortek KT-2938F
« Reply #1 on: July 30, 2010, 09:28:12 pm »
multi sync monitors usually have seperate HV and Hsweep circuits.
the Hsweep will likely have a mosfet xistor ( irf840a) driving an xformer/deflection output xisitor.
voltage will vary per sweep frequency. check components here as you would any H output stage.
always inspect for loose connections etc...
 can u post a fairly high res pic of both sides of the pcb ?
southmonitor
Re: Kortek KT-2938F
« Reply #2 on: August 03, 2010, 10:11:50 pm »
Hi:
Thanks for your reply. I found the Schematic with Casino Tech. Sorry I don't have a high res camera that can take good close ups of the board.
southmonitor
Re: Kortek KT-2938F
« Reply #3 on: August 03, 2010, 10:23:04 pm »
There was originally no HV up until I replaced the HOT and the IRF840A. Evenwhen both the HV and the H-sweep circuits are independent, because those transistors were shorted, they were imposing too much load on the PS and it was not starting the monitor with no HV either.
qrz
Re: Kortek KT-2938F
« Reply #4 on: August 04, 2010, 09:17:20 pm »
just seeing the print is an advantage  !
have a link , or can post/email it ?
