Author Topic: CP attaching graphics then drilling - good idea?  (Read 2866 times)
jpresto
  • Last login:March 24, 2012, 09:05:53 pm
« on: July 26, 2010, 12:55:32 am »
I'm going the NorthCoast and Mame Marquees route for my cabinet, with a tweaked 2-player CP layout.
Since I'll be adjusting the position of some items, i'm a bit worried about the alignment of the physical holes being off from my graphic. I was thinking of ordering a blank panel, attaching the CP graphic and then drilling the holes myself. Is this a practical approach?
Thanks in advance - Joe
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: CP attaching graphics then drilling - good idea?
« Reply #1 on: July 26, 2010, 02:02:15 am »
You could do that...  You'll have to be extra careful as the adhesive will stick to the drill bit and it will just tear the artwork.  I tried adding an additional button on my old control panel after the artwork was added.  Using a spade-bit through the top side of the artwork and it tore the artwork around the button hole.  Thankfully the tear wasn't wasn't too bad and I was able to fix it for the most part, but it was still noticeable after the button was put into place.
Ginsu Victim
  • Last login:May 24, 2026, 01:41:07 am
  • Comanche, OK -- USA
« Reply #2 on: July 26, 2010, 02:31:29 pm »
Wrong forum.
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
jpresto
« Reply #3 on: July 27, 2010, 01:24:51 am »
I noticed after submitting, sorry.. and first post to boot.
The plan would be to use another piece of wood with a hole predrilled, clamp on top of where i'd be drilling in the hopes of preventing tears. Of course if this doesn't work the fix would be a bit expensive.
Has anyone used this approach? If not, what was the trick to getting a template perfect against a custom mamerooms panel design?
Veeb0rg
  • Last login:May 31, 2017, 07:34:27 pm
« Reply #4 on: July 27, 2010, 04:58:19 am »
If your using a standard holesaw blade, just drill a bit in reverse to cut the CP overlay and the flip to forward and cut the wood.
« Reply #5 on: July 29, 2010, 11:58:43 am »
Id photocopy the art tape and drill
Ginsu Victim
« Reply #6 on: July 31, 2010, 06:30:14 pm »
Clamp your artwork to the cp. Use an ice pick or similar item to tap the centers of every hole to make a guide showing where to drill. Remove the art and drill. Attach the cpo and use an exacto knife to cut your holes.
