Author Topic: CONFUSED... How to output 8 liner game boards to PC monitors?  (Read 8688 times)
matt_3756
  • Last login:October 23, 2013, 07:06:43 pm
Ok so I have a small upright cherry master machine I got at a yardsale for $50. The CRT monitor is just about shot, can barely see the game, so Im trying to find out if I am able to output from the 8 liner boards to a VGA PC monitor. I found this on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350244621369&ssPageName=ADME:X:RTQ:US:1123
But I don't know how I would connect from the 8 liner board to this converter. Below is a pic of where the harness of a CRT monitor plugs into the board... so I am assuming I would need some converter or something to go from the game board as shown below, to some sort of converter to be able to display on a VGA PC monitor...? Any thoughts? Thanks!
BobA
  • What Me Worry?
Re: CONFUSED... How to output 8 liner game boards to PC monitors?
« Reply #1 on: July 26, 2010, 10:44:40 am »
The connector you have shown is the power and hopper power connector.   The video comes from the the larger 72 pin connector.  Check a manual for the board that you have to see which are the video pins.   I have attached a CM manual that may be of help.
« Last Edit: July 26, 2010, 10:52:27 am by BobA »
BobA
  • What Me Worry?
« Reply #2 on: July 26, 2010, 10:55:37 am »
A jrok converter maybe a cheaper alternative.   Lets you use a TV as a monitor.  JROK
matt_3756
« Reply #3 on: July 26, 2010, 12:51:13 pm »
Well I looked in the monitor chassis and the only wires I could find going to the cherry master main 72 pin harness is a small 6 prong connector that has r g b y and I think black... so would that just plug into the JROK? Using a tv monitor is fine with me, seems like it would be easier??
BobA
  • What Me Worry?
« Reply #4 on: July 26, 2010, 01:36:50 pm »
That 6 prong connector should plug right into the JROK board.   You should use a TV with S video in to get the best picture with the cheaper JROK converter.   Composite in on a TV is not as good as S video.  You will probably get the sharpest picture using the converter you were looking at on eBay with a PC monitor. However this depends on the quality of the up converter.
matt_3756
« Reply #5 on: July 26, 2010, 06:53:12 pm »
I am going to give the JROK a try. I am not very familiar with all the monitor technicalities but hopefully this should be pretty simple to install.
So are 8 liner boards like Cherry Master RGB or CGA? Whats the difference between the two or are they the same?
matt_3756
« Reply #6 on: July 27, 2010, 06:26:37 pm »
Does this guy selling the JROK still exist? I havent gotten a reply yet...
BobA
  • What Me Worry?
« Reply #7 on: July 27, 2010, 09:44:06 pm »
AFAIK he is still selling his boards but I do not know how fast he responds to emails.  Most people who do this sort of thing on the side can take a while to get back to you as life seems to get in the way.
matt_3756
« Reply #8 on: July 28, 2010, 07:43:31 am »
Im buying this instead: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360266251224&ssPageName=STRK:MEWAX:IT
Looks like it should work so I can use an LCD monitor. I hope!
BobA
  • What Me Worry?
« Reply #9 on: July 28, 2010, 10:02:09 am »
Looks like a good choice.
