Author Topic: Is plexiglass required? Alternatives?  (Read 2326 times)
transfan
  • Last login:April 07, 2011, 11:38:37 am
« on: July 16, 2010, 03:03:25 pm »
When building a control panel that you are going to put artwork on, is plexiglass (or lexan) a requirement?  Has there been success with laquers or resins, etc?
Also what's the best tool to get a trackball-sized hole into plexi?
Ginsu Victim
  • Last login:May 24, 2026, 01:41:07 am
  • Comanche, OK -- USA
Re: Is plexiglass required? Alternatives?
« Reply #1 on: July 16, 2010, 03:04:16 pm »
If you put a proper durable CPO on it, you won't need plexi.
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
jholman76
« Reply #2 on: July 16, 2010, 03:17:26 pm »
I laminated my CP and ALMOST didnt put plexi on it, but then my wife said
"what if I play it with my ring(s) on? wont it scratch it over time?"
one is a diamond ring so yes, it would over time, so I put the plexi on it. Its a lot easier to replace that than the laminate on the CP for my setup.
Or you could just polyurethane the CRAP out of it :) then it would be like a "built in" laminate!
joe
Franco B
« Reply #3 on: July 16, 2010, 03:40:04 pm »
If the CPO is Polycarbonate laminated it will be scratch proof and there will be no need for Acrylic etc overlay.
Mame Marquees/Game on Grafix and other decent printers should be able to offer this option for you.
I do however like the look of a glossy Acrylic overlay. The candy cabinets I'm working on at the moment don't use a Acrylic overlay but if I was to scratch build again I think I would use a Acrylic overlay.
If you do use a plastic overlay and need to cut the trackball holes you will find it will cut beautifully with normal router bits. You can use your CP as a template with a flush trim bit or you could make a ~3.25" template and then use that.
If you do use a plastic overlay use Acrylic (Plexiglass) and not Polycarbonate (Lexan).
I know its contradictory that Polycarbonate is used for CPO laminates :)
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
« Reply #4 on: July 16, 2010, 04:17:15 pm »
I personnally used envirotex. I used it for a countertop and my arcade control panel. It works well and it looks very nice.
You can check on their website where to find a retailer.
« Last Edit: July 16, 2010, 04:24:49 pm by ptinolv »
