Author Topic: MameWah Bug?  (Read 1380 times)
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
MameWah Bug?
« on: August 04, 2003, 10:55:40 am »
Hello,
I just started using Mamewah and I believe I found a bug.  Has this been reported:
If you are using multiple layouts per emulator and you hit 4 or 6 to change emulators, the list changes to the other emulator but the layout stays the same as the previous.  You must manual select 2 and then Select emulator to get the correct layout.  This should be corrected.
Thanks! Please let me know if I am wrong or how to fix this if it isnt a bug.
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
Re:MameWah Bug?
« Reply #1 on: August 04, 2003, 12:15:28 pm »
Well this is a bit misleading or I am not reading this correctly.  I know that when i switch from EMU to EMU using the 4 i get my different skins just fine (check your layout naming).  Although the way you wrote it sounds like you want to have different layouts for custom lists within the same EMU, this i don't think MW supports.  "Multiple Layouts per Emulator" as you wrote.  I know it supports Mutliple Emulators and Multiple Skins... Can anyone else help on this?
Superdude
Re:MameWah Bug?
« Reply #2 on: August 04, 2003, 02:06:10 pm »
No Actually you are right.  I want to have different skins for the different emulators. I just will have to double check my names.  I will report back.  Thanks for the help!
