Author Topic: MODEL2 GAME LIST - MISSING GAMES (SOLVED)  (Read 14648 times)
premier
  • Last login:October 10, 2020, 02:11:31 am
« on: July 11, 2010, 08:20:11 am »
Hey guys need some help,
For some reason MA wont display all the model2 games i have in the nominated rom folder.
seems to have happened to a few people judging from this cache thread from MA forums: http://webcache.googleusercontent.com/search?q=cache:BBbQq0_hOpIJ:maximusarcade.com/forum/index.php%3Ff%3D1%26t%3D1776%26rb_v%3Dviewtopic+Model+2+game+list+incomplete&cd=1&hl=en&ct=clnk&gl=au
does anybody have the .DAT file that is mentioned in the above thread,
or does anybody have another solution to the problem?
thank guys, really hope the forums go back up soon, or move to another server..
« Last Edit: July 25, 2010, 09:34:51 am by premier »
Re: MODEL2 GAME LIST - MISSING GAMES
« Reply #1 on: July 18, 2010, 01:42:36 pm »
**I have copied and pasted the posting you are referring to from the Maximus Arcade forums below for reference**
It looks like it was a custom model2.dat that Craize had.  We need to find a way to contact him?  Unless someone else has downloaded it prior to the forums going down?  Anyone?
** EDIT **  I have contacted the user Craize and he has attached the file below.  Enjoy!
** Original post by user:  CraiZE on Maximus forums **
Hey Guys! :)
I found the solution to our problem and actually have a small contribution to go along the way... Hope this helps somebody besides me :)
Fix for Incomplete Romlist
I found a fix to update the Romset to be read as the 0.9 one.... Here's How:
1) Download the attached .dat
2) Go into your Maximus Arcade\preferences Folder
3) Rename model2.dat to model2_old.dat
4) Copy "model2.dat" from the attached file Into your Maximus Arcade\preferences Folder
5) Restart Maximus Arcade
Now that we have the new .DAT in place, you need to rescan your roms... so, start up your MA and do the following:
6) Start up MA, once it loaded hit: CTRL + P to load up the Preferences
7) Go to the Configuration Tab and Select the Configuration for Sega Model 2
8) On the Bottom Select "Scan" and check the box that says "Force rescan of Media Folder"
9) Close
« Last Edit: August 08, 2010, 01:25:38 pm by DeLuSioNal29 »
Insayne
  • Last login:November 17, 2022, 04:19:53 pm
« Reply #2 on: July 19, 2010, 10:30:01 am »
Hey :)
After Delusional contacted me (I am CraiZE from MA) I came to post the updated .dat I once made :)
Enjoy!
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #3 on: July 19, 2010, 12:09:01 pm »
I think the mame list problem is unrelated to the Model2 issue.
I've posted a solution for you to try in the original topic:
http://forum.arcadecontrols.com/index.php?topic=104090.0
D
« Last Edit: July 19, 2010, 12:30:24 pm by DeLuSioNal29 »
premier
« Reply #4 on: July 25, 2010, 09:24:03 am »
thank you guys for your help!
much appreciated.
the model2.dat worked a treat!
« Last Edit: August 09, 2010, 10:42:05 pm by premier »
Re: MODEL2 GAME LIST - MISSING GAMES (SOLVED)
« Reply #5 on: August 08, 2010, 02:03:51 pm »
Quick question Insayne...  What did you do to the model2.dat file that makes it work correctly?  Just curious.
D
