Author Topic: Speaker Question  (Read 1395 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
Speaker Question
« on: July 10, 2010, 03:14:57 pm »
What is the best speaker to use with the 60 in 1 jamma board and what wattage AT power supply would 85 watts be ok?
BobA
  • What Me Worry?
Re: Speaker Question
« Reply #1 on: July 10, 2010, 03:49:42 pm »
Try a 8 ohm 4 inch speaker.  Very common in arcade cabs.  110 Watts is more commonly used in arcade cabs 85 watts is low but should work with your multi board as it has alot fewer components then an old arcade game. You can get a 250W ATX supply for about $25.
« Last Edit: July 10, 2010, 03:52:52 pm by BobA »
Darren01274
« Reply #2 on: July 10, 2010, 04:20:17 pm »
Hi Bob
With AT power supply will it turn on automatic without having to go through shorting pin 14? also what wattage speaker should I be looking at
BobA
  • What Me Worry?
« Reply #3 on: July 10, 2010, 04:37:36 pm »
AT supplies have a big switch on the side and do not use the computer MB connection.   The switch controls the AC directly from what I recall.  No pin shorting required.
