Author Topic: LED Wiz / LED Blinky - turn off on shutdown  (Read 4275 times)
86atc250r
  • Last login:February 22, 2012, 04:17:43 pm
« on: July 01, 2010, 12:54:25 am »
Hello all,
I've got a cabinet that has an LED Wiz, some RGB's in the buttons, and I'm running an older version of LED Blinky.
Problem is- I have a button that causes a windows shutdown when I want to power the machine down.   Thing is, the LEDs remain in whatever state they were in at the time the shutdown/power up button is pressed after the PC shuts down.   This has caused one of my blue LEDs to actually go out in one of the buttons and I can tell a couple others are beginning to go weak - this is after only a little less than a year's usage.
I'd like to know a way to issue an all off command before the shutdown happens.   I've tried a couple things now with no success.   Anyone got a script or some other method to get this done?   I've done a bunch of searching with no luck so far.
FWIW this is an XP box running MALA, LED Blinky, LED Wiz, etc...
Thanks in advance.
« Last Edit: July 01, 2010, 01:01:48 am by 86atc250r »
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
Re: LED Wiz / LED Blinky - turn off on shutdown
« Reply #1 on: July 06, 2010, 08:41:03 am »
Create a batch or script file and execute this command:
"<path>\ledblinky\ledblinky.exe" 2
Robots will kill you.
Arcade Addiction
86atc250r
« Reply #2 on: July 06, 2010, 10:14:10 am »
Cool, I'll give that a try -- tried something similar (can't remember the value I used) and it prevented the machine from shutting down.  We'll see if this works better, or maybe I need to cause the script to execute in a different manner (I used group policy editor to set the shutdown script).
