Author Topic: Cutting Holes In Metal Control Panel  (Read 10402 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: June 30, 2010, 07:57:53 am »
What can I use to cut the Hole Sizes in Metal Control Panel Over Lays. Need Buttons and Joystick Hole
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Cutting Holes In Metal Control Panel
« Reply #1 on: June 30, 2010, 08:18:54 am »
My CP is 1/8th inch aluminum, and i had the holes cut at our machine shop at work. Just regular hole cutters on a drill press.
Franco B
« Reply #2 on: June 30, 2010, 08:31:14 am »
If you don't have CNC access the two other methods you can use that will give clean results are a step drill in a drill press or a punch.
Step drill:
Punch:
I made a sheet metal control panel before with all low-tech tools, no lasers or anything space-age
1. A corded jigsaw with appropriate blade can cut the panel out (mine was shaped like a rectangle)
2. Pilot-point drill bits and a corded drill can make the carriage bolt holes
3. A radio chassis punch can cut 1 1/8" holes for buttons and sticks - I used chainsaw lubricant oil when using this.
4. An angle grinder to clean up the edges (maybe)
The punch works like this :
Mine was Greenlee Radio Chassis Punch #730, 1 1/8", I see them on eBay sometimes
(those aren't my pics but mine looked like that)
Working with metal is like 100 times slower than working with wood, but it can be done and it's not hard or expensive :)
Find a metal shop.  They can cut the CP in about 2 seconds and should only charge you a few $ for the effort...
Hey that's a good idea :)
Have fun!
Craig
Darren01274
« Reply #3 on: June 30, 2010, 09:40:45 am »
w
Darren01274
« Reply #4 on: June 30, 2010, 09:41:19 am »
What size holes for regular buttons and what size hole for the joystick. Is 1 1/8" for buttons same as joysticks
Cheers
Darren
« Last Edit: June 30, 2010, 09:54:17 am by Darren01274 »
Franco B
« Reply #5 on: June 30, 2010, 09:59:29 am »
1 1/8"  for most Happ style buttons (player and start)
30mm for most Japanese player buttons and 24mm for the start buttons.
For your joystick hole you can just use whatever size you use for the buttons.
Darren01274
« Reply #6 on: June 30, 2010, 12:18:06 pm »
Thanks for the replys guys  8)
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #7 on: June 30, 2010, 02:18:30 pm »
I used a 1-1/8" hole saw on my metal & wood panels.  Use a slow RPM use lots of cutting oil when cutting metal.  (Hopefully this a bare metal panel & not populated with controls & with an overlay.)
-Jason
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #8 on: July 02, 2010, 11:25:24 pm »
Are you going to leave it plain? I was thinking of doing this and then powder coating it at home with an old oven and a harbor freight powder coat gun.
