Author Topic: Midway Cocktail Control Panel  (Read 3534 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: June 29, 2010, 01:13:06 pm »
Hi I am wanting to purchase 2 new Midaway Cocktail Control Panels. Where can I purchase them, there is some on ebay for £100 way too much
BobA
  • What Me Worry?
Re: Midway Cocktail Control Panel
« Reply #1 on: June 29, 2010, 01:35:53 pm »
These look to be cheaper and you can design your own if you want.
Cocktail CPs
Darren01274
« Reply #2 on: June 29, 2010, 01:48:14 pm »
Wow thanks :-)
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #3 on: June 30, 2010, 03:53:41 pm »
that's the place I used.  I might even be able to find the template that I sent them.
My CPs for my MAMEd galaga cocktail machine are 3 buttons each, U360 sticks, and look like this:
http://www.waste.org/~winkles/winterMAME/pix/winterMALA.jpg
here's the templates to send to arcadeDepot for drilling:
http://www.waste.org/~winkles/winterMAME/pix/winterMAMEP1.jpg
http://www.waste.org/~winkles/winterMAME/pix/winterMAMEP2.jpg
and here's the overlay artwork that I ended up using, printed by mameMarquees
http://www.waste.org/~winkles/winterMAME/pix/winterMAME_mergedCPO.tif
This was all done about 2 years ago, things may have changed since then.
Darren01274
« Reply #4 on: June 30, 2010, 04:33:03 pm »
I downloaded the 11" panel template. I wanted player 1 and player 2 buttons small button for exit so I can get back to the game menu, Joystick and 3 fire buttons.
Would this layout work? or would it be too cramped.
« Last Edit: June 30, 2010, 06:23:01 pm by Darren01274 »
Franco B
« Reply #5 on: July 01, 2010, 03:15:31 am »
I think personally you want as much space between the joystick and buttons for a small CP like that. If you want to keep all of the buttons on the top of the CP I would suggest moving the coin/credit/esc buttons in the middle, something like:
If it was me though I would remove the coin/credit/esc buttons from the CP top completely and move them to the vertical face of the CP. You would be then left with more room on the CP top and I would do a layout like this:
I'm not sure if Arcade Depot give you the option to put holes in the front face. If they don't you could always put them in yourself or failing that I wouldn't mind doing them for you (I'm in the UK too  :cheers:)
If you do put them in the front just make sure they don't foul on the other buttons. I would use Japanese buttons which are much shorter and definitely wouldn't foul but you may have an issue with 'Happ' style buttons.
Darren01274
« Reply #6 on: July 01, 2010, 08:33:28 am »
Yeah I like that Idea will give it a try. Any ideas what I can do for a Taito Cocktail Cabinet it does not have a aluminium control panel like my Space Invaders one does. I thought about plexi but wasnt sure if I could cut the holes for buttons etc. I then thought about so thin wood painting it black and getting something printed?
Franco B
« Reply #7 on: July 01, 2010, 08:39:05 am »
What does your Taito cocktail have in the way of a control panel at the moment?
Acrylic (plexi) is easy to cut with the right tools and techniques.
