Author Topic: Lightgun with a sit-down cab?  (Read 3367 times)
Sky Zero
  • Last login:June 25, 2010, 03:14:58 pm
« on: June 24, 2010, 02:41:55 pm »
I only have room for one cab which I'm currently working on (Super Neo 29), just putting the finishing touches on the FE. I was curious about adding a couple of lightguns (specifically the aimtrak from ultimarc) to it for shooter games. Wanted to know of any experiences people have had in trying to add lightguns to their japanese sit-down cabs?
I think most shooters I played had a flat, vertical screen whereas the candy cab has a slanted screen. Any thoughts?
Thanks for any help!
Hurray Banana
  • Last login:October 18, 2016, 02:11:08 pm
  • My unique teaching style
Re: Lightgun with a sit-down cab?
« Reply #1 on: June 24, 2010, 02:56:02 pm »
The naomi shooters, like confidential mission etc... work on the naomi uprights.
You might need to stand up to play
Cheers Eric
TZ Pinball, PowerDrift upright, 4 vertical Mame cab and 8 way 2 player Mame cab
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #2 on: June 24, 2010, 08:13:53 pm »
I'm still trying to figure out how Sega got away with making a Crazy Taxi upright in that same model of candy cab.  Upright... Driving... It sounds like madness to me.
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« Reply #3 on: June 25, 2010, 07:06:02 am »
Thats a sweet cab, got a comfortable bar to sit on and everything  :laugh2:
Franco B
« Reply #4 on: June 25, 2010, 08:10:00 am »
There were a few Naomi upright drivers - Crazy Taxi, 18 Wheeler, Jumbo Safari - off the top of my head. They worked surprisingly well to be honest.
As far as lightgun go, I have played some Dreamcast lightgun games on one of my sit down Net Citys and it works great.
I tried to use the same set-up on a upright Naomi where the monitor is at the same height as that Confidential Mission cabinet (funnily enough it was a Confidential Mission cabinet that I converted to JAMMA) but the accuracy was terrible. I couldn't even get the guns to calibrate properly.
This is because the DC lightguns are meant to be used roughly at 90 degrees to the screen. When playing stood up at my sit down cab the barrel is at 90 degrees to the screen. When playing stood up at the stand up machine the barell is no longer at 90 and that's why it does not perform properly.
Confidential Mission and some other arcade shooters work using different technology (you can see the gun sensors in the bezel of that video) and so standing at an angle isn't an issue.
I have no experience with the aim tracks and don't know how they work but I would imagine they work on slanted screens as many peoples arcade cabs have slanted monitors. I'm sure someone will be able to tell you though.
