Author Topic: Computer IR  (Read 2814 times)
Valence
  • Last login:June 15, 2004, 10:44:49 pm
Computer IR
« on: August 03, 2003, 02:47:45 am »
http://www.ziplabel.com/cir/index.html
This is a good site that has a circuit design for making basically a universal remote controlled by the computer. Could solve all the "No usable signal" problems a lot of people suffer from.  I found it awhile ago and was going to use it for home automation stuff. Kinda got side tracked with another project but I think that I will use it for my TV.
gyruss
  • Last login:September 20, 2004, 06:51:38 am
  • No coins detected in pocket ...
Re:Computer IR
« Reply #1 on: August 03, 2003, 09:15:35 am »
Thanks - I've been thinking about home automation for a while and this might just get me going on it (after the current projects, of course  ;)).
TalkingOctopus
    • My Arcade
Re:Computer IR
« Reply #2 on: August 03, 2003, 05:12:30 pm »
I just hacked up a universal remote to make it power on a tv through a pushbutton.  This is an interesting alternative.
Justin
  • Last login:April 19, 2026, 10:09:37 am
    • Centipede MAME cabinet
Re:Computer IR
« Reply #3 on: August 03, 2003, 05:18:22 pm »
I'd like to do the same.  COuld you post some pics/info on how you did this?
"3 warps to Uranus" -- so I stopped playing!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Computer IR
« Reply #4 on: August 03, 2003, 05:23:59 pm »
Look up x10 too.  Most of the protocol are open source so you if you have programming experience you can program for their modules.
TalkingOctopus
    • My Arcade
Re:Computer IR
« Reply #5 on: August 04, 2003, 11:25:04 am »
I bought a cheap (~ $8) RCA universal remoter.  Busted off the plastic case.  Under the power button there are 2 strips of rubber like plastic.  I scraped those off.  Underneath are some copper wires.  I attached the NO part of the cherry switch to one of the strips of copper and then the Ground to the other strip.
Make sure to program it for your tv before you start!
It is really simple, if you just look at the board inside you should be able to figure it out by experimenting.
Sorry for no pics but I do not have a digital camera.
Good Luck!
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
Re:Computer IR
« Reply #6 on: August 04, 2003, 12:16:12 pm »
I have a ton of X10 stuff from Radio Shack. They made pretty goo stuff.
Visit my MAME lightgun site:
http://www.lightgun.tk
