Author Topic: Button Mapping issues  (Read 1286 times)
jeffrp
  • Last login:June 12, 2010, 09:41:10 am
« on: June 10, 2010, 10:31:34 am »
I have a 2-joystick/trackball set up and I have been able to map the joysticks and 6 bottons for each stick, but none of my other buttons (1-2player, start, reset, etc) or trackball are working. I've gone to the game controller panel on the PC and all it sees is the joysticks and game buttons (6 buttons). But in the device manager, it sees all 22 buttons. I'm using Maximus Arcade as my frontend and it only sees the joysticks and 6 game buttons. I double checked all my connections and everything is hooked up correctly. I'm just hoping my happ control board isn't messed up. Anyone else had this problem before? Any tips/suggestions? Thanks!!
BobA
  • What Me Worry?
Re: Button Mapping issues
« Reply #1 on: June 10, 2010, 02:07:12 pm »
It might help to specify which Happ Control Board you are using.  If it it the USB HID one I have not seen any mention of anyone using it in the forums but that does not mean that there isn't someone around that also has one.
jeffrp
« Reply #2 on: June 10, 2010, 07:29:21 pm »
I'm using the Happ UGCI board:
http://www.happcontrols.com/joysticks/950800xx.htm
yeah, i didn't find anything in the forums either. I hope that's not a bad sign  :-[
