Author Topic: Neo geo, any difference between console cartridge to arcade cartridge?  (Read 8851 times)
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
Hey guys,
I am running maximus arcade and I know you can have a separate section for Neo Geo in the home systems.
My general question, if I have the complete mame romset (including Neo Geo roms), is there any reason to run the emulator for the "home system"?  Are the home system roms the exact same as the ones mame/arcade runs?
I didn't know if the home systems ran any games the arcade neo geo wouldn't run or something.
Probably a dumb question, but thanks for the help.
« Last Edit: June 08, 2010, 03:05:37 pm by nickynooch »
There's some minor difference like options screens or some soft dip settings, but having both I prefer the arcade versions.
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
This is probably something more specif to Maximus and you may want to ask there. (as a "Home System" isn't related to MAME in anyway).
But ... I do know that many NEO-GEO games run a bit slow when using MAME emulation (ie. Metal Slug series). There are NEO-GEO specific emulators that will run them more smoothly/correctly (if comparing with an actual Neo-GEo cab.
Can Maximus support those? Or which can they support? I'd head over to the Maximus forum to answer that one.
nickynooch
I get why you would direct me to the Maximus board, but I guess I phrased it wrong.
What I am trying to say is, are the games on a neo geo console any different whatsoever to the neo geo arcade system?
That's pretty much my point.  Not really about maximus arcade.  I probably should have left that out of the talk.
Yes, Maximus supports winkawaks and mame being two of them.  I guess I just didn't understand if the game cartridges were literally the exact same thing from arcade to neo geo console.
dgame
  • I am no Jedi
The MVS behave like arcade games and thus you can usually buy [credit] your way through the games.
The AES behave like console games and thus you usually have limited continues.
The game play is generally the same.
nickynooch
Thanks!  I was wondering what differences there were.
WhereEaglesDare
    • My HomePage
I read somewhere that Neo Geo Home Version of MetalSlug had special side missions and challenges or something like that.
Haze
    • MAME Development Blog
you read wrong.
For AES/MVS the roms are (for the most part, there are exceptions) the same.
There are different code paths depending on the bios being used, which in the case of the home bios will mean you're presented with an options menu, where you can select the difficulty, and given a limited number of credits to complete the game.  If the arcade bios is used then all the options (difficulty etc.) are selected by the arcade op, and the number of credits you get depends on how many coins you insert.
The physical carts are incompatible, but you can buy adapters to run either on either, because the actual content is the same, and will operate in arcade / home mode depending if you're running on an aes/mvs motherboard.
