Author Topic: Golden Tee 2005-VGA to LCD Question  (Read 9473 times)
North Peoria
  • Newbie
  • Last login:June 08, 2010, 12:56:40 pm
« on: June 08, 2010, 12:13:25 pm »
I created a stand alone Golden Tee 2005 for my brother. For the video I elected to utilize the video card's VGA output. However, I recently discovered that the output is actually EGA 512x384 at 25kHz. The resolution isn't the problem, though, it's actually the 25 kHz scan rate. Without retooling using a hard-wired Video Converter, does anyone know of any readily available LCDs/Monitors that would accept that output? I need to buy one anyways so I'd rather just find one that accepts that signal without having to convert it.
TOK
  • The Game Always Wins
Re: Golden Tee 2005-VGA to LCD Question
« Reply #1 on: June 08, 2010, 08:51:13 pm »
Happ does, but they are very expensive.
http://www.happcontrols.com/monitors/49286100.htm
StephenH
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #3 on: June 29, 2010, 10:41:52 am »
Yes there are a few issues you need to consider if converting to LCD:
- anything that size will be wide screen.... 16X9 aspect ratio, but after you play it I am sure you will love it!
- Be careful about viwing angle as well as contrast/ brightness... I have carefully selected our make and model of LCD panel to insure optimum!
- If you use a scan converter, you are essentially converting the signal once so that the 25Khz is now VGA (640X480) the LCD's A/d board will likely convert it again to the lCD panels resolution such as 1024X768... double conversion means degradation of the picture. Our LCD does not need a scan converter.
- next the IT cabinet needs special attention to add a 26" LCD as they added 5/8" particle board on both the right and left sides- inside the cabint. This reduces the mounting opening by 1 and 3/4 inches so some of that needs to be cut out if you are planning on using the original cabinet.
I have already putthese in GT2005, PGA, GTA Complete and a whole lot of others and they look great... odd for me to be saying that as apicture tube fan, but all the work we have done has paid off.
Hope this helps.
Good luck Rick
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
lilshawn
  • Last login:June 07, 2026, 05:26:02 pm
« Reply #4 on: July 01, 2010, 01:10:42 am »
*slow clap* good writeup!
