Author Topic: Hantarex Monitors  (Read 2293 times)
xrodney
  • Last login:August 31, 2023, 09:57:19 am
Hantarex Monitors
« on: June 02, 2010, 03:27:03 am »
Hi
does some one knows which models are these hantarex monitors?
CIN 25" A59 EAK 552X11
CIN 25" A59 EAK 552X44
CIN 28 16/9 W66ERF 142x44/17
CIN 34" A80 AEJ 15X99 - 15X0
CIN 34" M80 EPE 14X122
CIN 29" A68 EES 038X322/678
CIN 29" A68 ERF 142x044/M T.
CIN 28" A66 EAK 552X11
CIN 25" A59 EGD 048X 322
regards
Rodney
lilshawn
  • Last login:Yesterday at 05:48:23 pm
Re: Hantarex Monitors
« Reply #1 on: June 02, 2010, 11:52:42 am »
these appear to be tube numbers not model numbers.
try again. there should be another label on the actual electronics portion that will provide more info.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: June 02, 2010, 04:00:56 pm »
philips a59 and a66eak071x44 are taken for the polostar multisyncs. they are also used for 100 hertz tvs ( x44 ) deflection unit . x01 and x11 are lowres polostars with philips tubes.
xrodney
« Reply #3 on: June 03, 2010, 01:10:03 am »
Which are the best in your opinion?  i found these monitors and I want to buy 1 or 2
Rodney
apfelanni
« Reply #4 on: June 03, 2010, 04:51:20 am »
2 be honest , i wouldnt buy any of it unless its a bargain . the newer multisync polostar have crappy chassis . they usually die after a few years , maybe 3/4 within 5 years. the older ones are ok , but nowadays u can achieve the same pic quality witch a 10 euro rgb tv . the philips tubes in hanta and tvs are 100 % identical. the only benefit would be the multisync feature, which is overrated in my opinion.  i got nearly 1o cabs and not a single with multi or trisync and i dont miss it.
« Last Edit: June 03, 2010, 04:53:36 am by apfelanni »
xrodney
« Reply #5 on: June 04, 2010, 04:09:00 am »
can, can you give some feedback on
MTC28EV/3 can be used for VGA/SVGA input
piece MTC 28 EQ/3 for all 15kHz signals
regards
Rodney
