Author Topic: saving high scores in mame.. ive read the thread i just can't figure it out....  (Read 4310 times)
greenday8616
  • Last login:March 01, 2012, 08:12:42 pm
ive read about adding the high scores back into mame and i know that i need to recompile a new version.. ive tried to do this and spent hours messing around with it.. is there a version thats already precompiled or another mame version that i can just download.. it has to be something that will support command line tho
WhereEaglesDare
    • My HomePage
I am using 138 and I am pretty sure it is saving my high scores.
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
Wheres the thread? I was going to ask about this too
My MAME Build:
Don
  • Last login:March 26, 2024, 04:39:03 pm
Its stickied - http://forum.arcadecontrols.com/index.php?topic=64298.0
Btw is there anywhere to download pre-compiled versions of mame with hiscore supported??
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
There is MAMEUIFX but on their website you can only download the latest version : http://mame32fx.altervista.org/home.htm
dgame
  • I am no Jedi
CabMAME does:
http://community.arcadeinfo.de/showthread.php?t=9555
You still need put a highscore.dat in your MAME folder and a create a "hi" folder in your MAME folder.
/MAME/cabmame32.exe
/MAME/highscore.dat
/MAME/HI/
cabmame32.exe can be renamed to mame.exe
greenday8616
so would you guys recommend that mameuifx or cabmame.. are they both command line?? could i just set mala to run those and change it to my current button assignments and be done with it?? or would it be complicated??
ptinolv
I was actualy not aware of cabmame, so i cannot advice you on which one is best. Both should work with command line. The easiest thing is the rename the cabmame.exe/mameuifx.exe to mame.exe, and the command lines are exactly like mame. If you already have a mame with your controls configured, you can copy the folder ./cfg/ to the Cabmame/mameuifx folder.
Don
Does anyone have, or know where i can download, the 0.128 version of CabMAME or MAMUIFX?
greenday8616
thanks for the help guys!
greenday8616
i got the high scores working but now the display is messed up... the screen is about half as big as it used to be so now i am not using all of my moniter... my front end displays properly but when i run mame the entire display is in the center of the screen.. my neo cps emulator runs everything at full screen however... so i know its something with the mame settings but i dont know how to fix it... i've gone thru the configuration and looked through the ini file.. i have no idea what to do to change it... all i really need is for the games to display at about twice the size they currently are in the window i just dont know how to change that... any ideas.. ive gone been messing with the resolutions and tried to use the stretch options in the config tab for mame in mala.. everything i dont know what i did wrong
greenday8616
cabmame is working fine on this computer but when i tried it on the comp in my laptop first i had the issue with the screen then it would not work at all... it was saying it wouldnt find the right direct draw and direct x drivers and whatnot same file and everything.. its just a normal computer with xp on it... any ideas???
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
Your missing drivers, have you re-booted recently?
