Author Topic: Craziest Game Controllers  (Read 3768 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
Re: Craziest Game Controllers
« Reply #1 on: May 28, 2010, 06:17:10 pm »
Wow.  The relevant-info-per-page value is very low in this "article".
danny_galaga
  • Last login:Yesterday at 07:41:18 am
    • dans cocktail lounge
« Reply #2 on: May 29, 2010, 12:40:02 am »
I've played on that Steel Battalion controller. It's freakin' awesome! There's even a safety 'flip switch' for Eject and a button for the window washers! Made me want to buy a modded or US x box just for that one game...
MidnightMenace!
  • Last login:April 19, 2011, 01:55:22 am
« Reply #3 on: May 29, 2010, 05:33:58 pm »
i dont really consider ROB a controller?? he actually holds in his hands a normal controller
SavannahLion
« Reply #4 on: May 30, 2010, 03:02:54 am »
Yeah, ROB is kind of a strange choice. I don't think the author really knows their ---steaming pile of meadow muffin---, though they did pick up on the SEGA Activator.
A few things left out:
NES:
ASCII Stick L5
Konami Laser Scope/Gun Sight
U-Force (I actually wanted this when it came out)
2600:
Milton Bradley Cosmic Commander (Came across this while trying to figure out what the U-Force was called.)
PC:
DX1
A one handed keyboard meant for FPS gamers, I think this was called the Stingray?
Not really unusual per se, but I thought it worth mentioning in its context. Came across this when I was trying to decide if the Jaguar controller would qualify.
SNES:
I'm sure there's a ---steaming pile of meadow muffin--- load of controllers I've forgotten about. With about 25 years of game time, I'm sure I've seen more than a few bizarre console controllers.
northerngames
  • Trade Count: (+18)
« Reply #5 on: June 01, 2010, 09:20:46 am »
Snes super scope 6?
the way it is listed example wise the GC mic with odama could be in there too.
« Last Edit: June 01, 2010, 09:23:15 am by northerngames »
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #6 on: June 12, 2010, 09:47:10 pm »
I had the U-Force when I was a kid.  I tried every game I had when I first received it.  The only game that even REMOTELY worked was Mike Tyson's Punch Out... and even then, it was incredibly bad.
The operable range from the sensors was generally about 1 inch.  I remember it being initially responsive, but you had to COMPLETELY remove your hand from the beam before it could register another input... and *then* it would lag on you on the next input.
The port where that joystick plugs in?  Basically just a recessed notch over an internal D-Pad.  You could stick your finger in it and control Mario!  (That doesn't sound right...)  And nothing physically held the joystick in that port; you could pull it out at will -- right in the middle of the game, typically.
Also, those great big red buttons on the joystick piece? They were spring loaded, and all they did was manually flip a reflective(? can't remember) paddle on the bottom of the handle which would then trigger the sensor below them... but again, only when you were DIRECTLY OVER THE SENSOR... kinda hard to play most games when you can't move and do an action at the same time...
You could even lay it flat (as opposed to that 90 degree angle) and access the sensors that way... but that was like playing with an awkward, over-sized, under-sensitive bastard Theremin on crack.
Altogether, it was like the devil design spawn of the Stanford Prison and Milgram Experiments.  With a little Hitler thrown in.
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
« Reply #7 on: June 13, 2010, 09:55:41 am »
aw was it really that bad. ive only seen it in AVGNs review and it diddnt seem too bad. lol
SavannahLion
« Reply #8 on: June 14, 2010, 03:47:38 am »
FIRE! FIRE! FIRE!  :censored::censored:! FIRE!
I couldn't stop laughing.
