Author Topic: Dumb question about disconnects  (Read 922 times)
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« on: August 01, 2003, 12:05:59 am »
I'm sorry this is such a stupid question :D
When you use female disconnects do you run the wire through the little grooves on the side of the metal part, or just leave it in the middle?
TalkingOctopus
    • My Arcade
Re:Dumb question about disconnects
« Reply #1 on: August 01, 2003, 12:15:11 am »
I don't think it really matters.  Just jam the wire in the hole and use the crimper to smash the disconnect down.
Test your work by giving the wire a tug.  It should not budge or be loose.
Apollo
    • Eight Bells
« Reply #2 on: August 01, 2003, 12:34:13 am »
It sounds like you are using them incorrectly. The metal part with the 2 grooves is for the microswitch connection, your wiring goes into the small end, either 1 wire or 2 depending on what you are doing. Sorry in advance if I misunderstood you.
