Author Topic: Building a monitor frame  (Read 2101 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: May 18, 2010, 06:34:18 pm »
Does anyone have any experience building a frame for a monitor?  I've got a cabinet without a monitor in it and need to mount something.  I'm thinking a big VGA or a TV with the case removed.
lilshawn
  • Last login:June 16, 2026, 07:23:28 pm
Re: Building a monitor frame
« Reply #1 on: May 18, 2010, 09:09:31 pm »
it should already have some brackets in there to mount a tube.... have a looksie!
if not...the easy way would be to leave the case, and build a shelf in there to set the TV on.
WhereEaglesDare
    • My HomePage
« Reply #2 on: May 31, 2010, 03:37:20 pm »
Here is what I did.
Here is my TV mounted
The brackets were kinda offset next to the tube so I had to make extensions for the bracket.  You may need to add a 2x4 to the top and bottom and use wood screws so that you can mount the TV down to something.  I used 3/4" 5-ply plywood.
And then I put a shelf in there to hold the boards
Then I put the bezel on it and the Plexi and viola...
Works Great!
« Last Edit: May 31, 2010, 03:40:25 pm by WhereEaglesDare »
