Author Topic: ipac2 timed out problem  (Read 1689 times)
robsteph0217
  • Newbie
  • Last login:May 17, 2010, 01:00:29 pm
« on: May 14, 2010, 07:51:40 pm »
 :angry: i have windows xp and ps/2 ipac2  every time i click program it times out i changed the time out setting and still nothing. do i ned internet to make this work? what am i doing wrong????? please help my boys are driving me nuts wanting to play thanks
Hoopz
  • Last login:June 09, 2026, 10:42:21 am
  • Intellivision Rocks!
Re: ipac2 timed out problem
« Reply #1 on: May 14, 2010, 09:47:35 pm »
From the Ultimarc website:
Problem: Cannot program. Utility hangs at end of programming.
If you are using the PS/2 connection, and do not have any USB keyboard on your PC, you will need to check that in the PC BIOS, "USB keyboard support" or "Legacy USB Support" is DISABLED, otherwise WinIPAC will not program properly.
Another cause of this is having non-switch items connected to inputs. In general, the inputs must be "open" (ie no switch pressed) for programming to work. This may not be the case if you have other things connected such as a game board connected at the same time as the I-PAC. Email for further advice on this if you must have other devices connected as there are workarounds.
Try that and see if it helps.
