Author Topic: Megatouch Game- Why is it shocking me?!?!?!?!  (Read 2683 times)
matt_3756
  • Last login:October 23, 2013, 07:06:43 pm
« on: May 10, 2010, 10:28:30 pm »
I have no idea what is going on here. I turn my megatouch game on and when you touch the touch screen you get a tiny shock. You also get shocked on other parts of the machine as well. It ran fine at my grandparent's house and last night at my house. I go to turn it on just now and I couldnt get it to stop shocking me. Its like its doing it randomly, I have no idea. I got it plugged into  a power strip all 3 prongs and the power strip goes to an extention cord, to my outlet in the house. None of my other machines on the power stip produce a shock.  :banghead:
Ken Layton
  • Guru
  • Technician
Re: Megatouch Game- Why is it shocking me?!?!?!?!
« Reply #1 on: May 11, 2010, 12:04:28 am »
The ground wire of the touchscreen glass is either not connected or is poorly connected.
WhereEaglesDare
    • My HomePage
« Reply #2 on: May 11, 2010, 07:53:30 pm »
agreed, the power is building up because it cant get through to ground...
matt_3756
« Reply #3 on: May 13, 2010, 11:21:20 pm »
well I connected it directly to another outlet in my house and it's working fine so I have no idea.... could a bad power strip or extension cord cause that?
WhereEaglesDare
    • My HomePage
« Reply #4 on: May 14, 2010, 01:03:29 pm »
Could, I would check the ground connector on that outlet.  Google it
Kevin Mullins
    • Me on Myspace
« Reply #5 on: May 14, 2010, 01:46:19 pm »
Could also grab a ground fault indicator/tester for testing outlets for @ $6-7 at most hardware stores and such.
You may have an open ground on that particular outlet.
Can also test your power cords and power strips just the same.
