Author Topic: PC Help for a Mac user  (Read 10486 times)
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
Hoopz
  • Last login:Today at 07:08:07 am
  • Intellivision Rocks!
Re: PC Help for a Mac user
« Reply #41 on: May 14, 2010, 05:16:14 pm »
Same site that I think he was at (and that I pulled up).  I think he needs to install the chipset driver first, then go with the graphics driver.
92greenyyj, from that link, download the file that says:
Intel 845G/GV Chipset Support for Windows 2000/XP
Install/run it.  Reboot, then try the graphics driver again.  We'll see if that did it.
andrewbean90
  • do you like it?
« Reply #42 on: May 14, 2010, 05:24:42 pm »
actually Intel 845G/GV Chipset Support for xp home or professional also install all the other drivers too it will help even if it seems like bull
« Last Edit: May 14, 2010, 05:29:30 pm by andrewbean90 »
abispac
  • Last login:Yesterday at 11:24:52 pm
« Reply #43 on: May 14, 2010, 07:30:47 pm »
tooooooooooooo many problems installing tyni xp or any modified version of xp, ill say, if you got a brand new sealed version of xp , install that , i recomend a brand new installation, once installed , go to windows update and it will automaticly download your drivers, ill pm yuo an original serial so you can install that and stop having so much trouble. f u c k modified versions ox windows, use only originals....
andrewbean90
  • do you like it?
« Reply #44 on: May 14, 2010, 07:39:30 pm »
I agree with him^^^^^^^^ alittle bit except the fact that xp updates the wrong kind of driver go to that website
abispac
« Reply #45 on: May 14, 2010, 07:51:12 pm »
i have been using windows update for my drivers , on clean installs , so far ill give it a 98% succes, the other 2 was for an update on my wireless card that gave me less signal, but i never panic, i went back to the old driver, and was ok again.
andrewbean90
  • do you like it?
« Reply #46 on: May 14, 2010, 07:55:55 pm »
ya but sometimes you cant get windows update drivers without a driver from the website first and I always bluescreen when updating drivers through windows update as in after it restarts of course
92greenyj
  • Last login:January 02, 2012, 06:19:41 pm
« Reply #47 on: May 14, 2010, 09:39:53 pm »
I got XP working fine a few days ago. Thats no longer an issue, but I appreciate the help.
On that note I did run the updates when the bubble prompted me too, but it was all security updates and a few XP OS updates. i didn't see a single driver update in the list.
Hoopz
« Reply #48 on: May 14, 2010, 09:44:22 pm »
You'll rarely see a driver update.  The one thing to do though is look at the "Hardware, Optional" button and see what's there.  I'd bet it doesn't show a driver, but who knows?
Encryptor
  • Trade Count: (+34)
« Reply #49 on: May 15, 2010, 09:51:54 am »
Usually the only thing the bubble updates are for is critical updates. You need to go to the update page and look on the left side of the screen under software or hardware.
Encryptor
92greenyj
« Reply #50 on: May 16, 2010, 02:19:20 pm »
ok. Ran the chipset update. rebooted. everything seemed fine. MAME still wouldn't launch. So I downloaded MAME .116. couldn't get it to launch thru the command line. tried running thru MALA .104 after screwing with that for 10 minutes it finally launched MAME .116 to the same errors I was getting on .137. downloaded the graphics driver update again, ran and rebooted. same thing. signal not supported. rebooting in safe mode now to remove the drivers again.
I'm thinking maybe I should go get a PCI graphics card???
andrewbean90
  • do you like it?
« Reply #51 on: May 16, 2010, 07:21:39 pm »
ask the people on mala maybe a mala problem
andrewbean90
  • do you like it?
« Reply #52 on: May 16, 2010, 07:27:03 pm »
btw did you ever install those graphics drivers they usually need something installed before they can be installed
92greenyj
« Reply #53 on: May 16, 2010, 09:33:22 pm »
yeah. I did the chipset driver. than the graphics bios driver. then the graphics driver. after i did the graphics driver and re-booted I got a bubble floating on the monitor that said input not supported. same thing that happened last time I tried to install the graphic driver from HPs website
andrewbean90
  • do you like it?
« Reply #54 on: May 16, 2010, 10:38:42 pm »
input is usually mouse and keyboard output is monitor
andrewbean90
  • do you like it?
Hoopz
« Reply #56 on: May 17, 2010, 09:38:25 am »
I think you're going to have to just slap a PCI card in there and go with that.  You should be able to find one very cheaply.  I wouldn't pay more than $10 or so.
Post a message in B/S/T and see if someone will send you one for shipping.
andrewbean90
  • do you like it?
« Reply #57 on: May 17, 2010, 01:03:24 pm »
http://www.aocdisplay.com/envision/manuals/Input_Not_Supported_Win2K_XP.pdf
i'd try this first before spending hard earned cash
92greenyj
« Reply #58 on: May 17, 2010, 02:28:34 pm »
thanks andrew. I'll give that a try first. then If that doesnt work I'm gonna go grab a PCI video card. I need to go to Fry's tommorow on my day off anyway. want to get some more ram for this thing for starters. its kinda crawling with only 256 megs in it
Hoopz
« Reply #59 on: May 17, 2010, 04:00:45 pm »
I wouldn't buy anything new for that PC.  Odds are that someone will get you a great deal.  You'll probably struggle to find a PCI card in a retail store.  If you find one, it's gonna be much higher priced than a deal someone can cut for you.
Same goes for RAM.  Don't buy it new if at all possible.
92greenyj
« Reply #60 on: May 17, 2010, 05:28:09 pm »
Hoopz,
guess your not familiar with Frys. :D
its an electronics warehouse store. cheapest and best source around for pretty much anything and everything electrical.
Hoopz
« Reply #61 on: May 17, 2010, 09:02:34 pm »
I've been to Frys. I just think that they'll charge you for something that a lot of us here have laying in a bag somewhere of old pc stuff. Seriously, anyone who has one should give it to you for a couple bucks at the most. PCI has been passed by AGP and then PCI-E. Nobody is keeping one for a special project, I hope!
92greenyj
« Reply #62 on: May 18, 2010, 12:41:27 pm »
thank you andrew!! that worked! finally its running on the updated graphics drivers. Now i gotta go see if MAME will launch or not
92greenyj
« Reply #63 on: May 18, 2010, 12:46:22 pm »
YES!! MAME .116 launched thru MALA .104 mo problem!! I can't thank you guys enough for all your help! I'm sure i will have more questions as I progress further into this project.
andrewbean90
  • do you like it?
« Reply #64 on: May 18, 2010, 03:19:48 pm »
no prob dude technically im a computer expert (somewhat) even though im only 20 in 1994 was my first computer cdrom install thats right i did it when i was 4 and havent had a computer act up on me without knowing how to fixit until then when you asked for help it was a good learning experience
abispac
« Reply #65 on: May 19, 2010, 01:34:28 pm »
92greenyj
« Reply #66 on: June 08, 2010, 10:44:34 am »
ok, new problem. Now I'm stuck in an endless loop and can't log into my computer! I had to do a restart. Now when it starts up I get a pop up window that says: "This copy of windows must be activated before you can log on. Do you want to activate Windows now?" I click yes. it loads the background and the big Windows product activation window. The window says "Windows is already activated. Click OK to exit." nothing else there. so I click OK. it takes me back to the log in screen. I click my user and get the same message and the cycle repeats. I tried booting in safe mode and logging in as both admin and user but that didn't work either. Wouldn't let me past the log in screen. Said the product can't be activated in safe mode. WTH??? Any suggestions?
92greenyj
« Reply #67 on: June 08, 2010, 11:43:28 am »
disregard. After 30 minutes of google searching I finally found a fix that works
