Author Topic: For want of a belt  (Read 1606 times)
SavannahLion
For want of a belt
« on: May 02, 2010, 02:32:24 am »
My Future Wife's favorite DVD recorder (Samsung DVD-R120) simply refused to open the door/tray one day. So I agreed to take a look at it. After fiddling around a bit, as near as I can figure the belt is finally worn out. If I remove the DVD drive cover (with the magnetic disc) from the equation, the drive functions perfectly. Replace the cover, and it refuses to open.
I believe the strength of the magnet is too much for the worn belt to overcome.
So... where might I source a replacement belt?
Note, this isn't a computer drive. It's an actual DVD player/recorder deck.
CCM
Re: For want of a belt
« Reply #1 on: May 02, 2010, 12:33:24 pm »
Search ebay for DVD-R120... there are some 'as-is' and some that need work... you may be able to pick one of them up dirt cheap to use as parts.
« Reply #2 on: May 02, 2010, 03:20:14 pm »
That or a big honkin rubber band might work.
I just used a bicycle brake cable to fix the seat back release mechanism in my wife's bmw. The dealer wanted more than 100+ to even look at it  :angry:
lilshawn
« Reply #3 on: May 03, 2010, 01:24:22 am »
a layer of electricians tape on the magnet could be enough to overcome the force causing it to stick.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: May 06, 2010, 08:10:24 pm »
MCM has some belts for electronics like this. Check with the to see if they have what you need.
