Author Topic: my problem emu's, any suggestions?  (Read 1292 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« on: April 26, 2010, 08:53:31 pm »
hi all,
after installing soft 15 and changing emu configs, i'm left with a handful of emu's that are still giving me some small issues.  fyi, soft 15 was installed so i can have my arcade cab at 1024x768 at 84hz which is what my projector is set at.  i've successfully gotten most emu's to run at this reso/refresh rate.  the emu's that are giving me a problem are causing my projector to lose synch, sending the projector to a black screen until it resynchs.
so, i'm looking for user feedback for the following emu's.  can i force them to play nice or should i start looking for alternatives and if so, any suggestions?  so here they are:
Jaguar - using Project Tempest 1.9.  i believe this emu runs at the jags native resolution which is causing my temporary projector black out on launch and exit.
Neo Geo - using Nebula (latest version).  this one is weird.  it does the black out resynch when starting the emu.  when quitting, it does not and returns me to my desktop with no issues.
EDIT: moving to winkawas, problem fixed
PSX - using psxfin, 1.13.  same exact issue as Neo Geo.
Saturn - using SSF 011 Alpha R3.  same issue as the jaguar, black screen on launch/exit
EDIT: upgraded to SSF 11 Alpha R5, problem fixed
any feedback is appreciated.  thank you for reading
« Last Edit: May 02, 2010, 06:03:05 am by tony.silveira »
