Author Topic: Need suggestion - where to install my spinner on my Tankstick  (Read 4242 times)
bclinton
  • Last login:November 12, 2014, 02:53:00 pm
Hi all - first post.....I have a turbo twist II coming and want to install in in my Xgaming Tankstick. Looking for suggestions on where to place it. Right now I am planning on only using 1 but want to leave the option for a second one later if I want to.
http://www.xgaming.com/store/category/arcade-joysticks-and-game-controllers/
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
Re: Need suggestion - where to install my spinner on my Tankstick
« Reply #1 on: April 26, 2010, 08:11:12 am »
I had mine where the 2-player button is. I rewired the bottom buttons of the 8 player buttons to be credit and the player start buttons. The button where the 1-player button used to be turned out to be useful for Tron -- you can spin with your fingers and shoot with your thumb. I liked this setup so much, I built it into my cabinet.
« Last Edit: April 26, 2010, 08:13:08 am by Triangel7D »
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #2 on: April 26, 2010, 09:39:31 am »
For the time being you can remove on of your existing buttons and drop the Turbo Twist II in there.  For me I would probably mount it under player 2 since I am right handed and mounting it in the middle might interfere with the trackball but that is just me.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
SammyWI
« Reply #3 on: April 26, 2010, 09:57:21 pm »
I mounted a Spintrak at the top of the left bar of the large X.  It's an OK spot, but not great.  Can't rest your hand without pressing buttons.  But you can rest your forearm below the buttons.  And, I should have checked what was under that location before I drilled.  The two front side buttons caused some interference so I had to add a small spacer under the flange of the Spintrak - lucky for me that worked.
I may look at moving it to one of the P1 or P2 button locations and move those buttons somewhere else.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: April 26, 2010, 10:35:06 pm »
Personally I'd mount it somewhere off the unit, perhaps on a proper arcade control panel along with some other controls.
I'm partially kidding. :) I'm just not a big fan of these units :)
Triangel7D
« Reply #5 on: April 27, 2010, 07:41:17 am »
I'm not a big fan of X-Arcade units either, but they're a mighty powerful gateway drug!  ;)
mytymaus007
« Reply #6 on: April 27, 2010, 11:16:54 pm »
around this area it doesnt interfere with the trackball at all
bclinton
« Reply #7 on: May 01, 2010, 12:54:28 pm »
Here is where I put it. Seems to work ok and looks ok too....
http://picasaweb.google.com/bill.c.clinton/Projects#5466345754056826018
