Author Topic: ZiNc Question/X-Arcade  (Read 5408 times)
MameMaster!
  • Engage number one!
    • Mame Invaders!
« on: July 30, 2003, 01:30:29 pm »
GREETS ALL.
I just installed ZiNc and ROMs.....(I own all of the original boards of course)....and it ain't working with my X-Arcade.
Specifically when I reconfigure ZiNc through a GUI I'm using (http://dafreak.emuhq.com/)....when I press what should be a light punch (Street Figher EX).....it goes into a wierd slow motion redraw kind of a state.
Any suggestions on what I may be doing wrong?
The MameMaster (obviously not the ZiNc Master!).
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re:ZiNc Question/X-Arcade
« Reply #1 on: July 30, 2003, 01:33:46 pm »
Does it work normal if you press the keyboard?
Does the xarcade work normal in a dos shell?
I thought xarcades is just a keyboard encoder... I don't have one so I don't know if it has any auto-repeat anything with it..
MameMaster!
    • Mame Invaders!
« Reply #2 on: July 30, 2003, 01:36:06 pm »
You know, to be honest I didn't even try the keyboard to check that out.
Since it works 100% in mame....I figured it would with ZiNc since it just mimics the keyboard. But, that's a good suggestion...I'll have to see if it does work or not with the default keys.
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« Reply #3 on: July 30, 2003, 02:03:16 pm »
You have one of two choices...
Provided that Zinc (never used it myself) allows you to map keys, then you can re-map the keys to match the X-Arcade's default.
Or second option (one of the big benifits of the X-Arcade encoder by the way)
Program one of the 4 custom key maps on the X-Arcade to match what Zinc is expecting for default input.
Programming the X-Arcade is very easy and works great.
« Last Edit: July 30, 2003, 02:03:58 pm by gndprx »
MameMaster!
    • Mame Invaders!
« Reply #4 on: July 30, 2003, 02:14:14 pm »
hmmmm....I forgot about the custom function. I'll give that a try!
I've already tried remapping ZiNc in the GUI but that didn't work......
But, the custom idea has promise!  ;D
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #5 on: July 31, 2003, 08:02:25 am »
I just got done doing remapping my Zinc keys to match the default mame keys.  I was able to remap them using the dafreaks zinc gui which worked fine when I loaded the games from gui, but I wanted to be able to load the games from mamewah and still have the key remappings in place which I wasn't able to do with the dafreaks gui.  I instead used ZINCFE to remap the keys and after doing so the key remappings stayed active when I used Mamewah.
     To be honest I can't remember where I downloaded it from but you could do a google search to easily find it or I could email it to you if you want. Let me know.
MameMaster!
    • Mame Invaders!
« Reply #6 on: July 31, 2003, 09:56:25 am »
 ;D SUCCESS!  ;D
I remapped the X-Arcade and that worked perfectly.
I checked to see if the default GUI keys worked and they did....so I just changed the X-Arcade to match the defaults and that solved the problem. I totally forgot about that function...that was a great idea to try that!
I found that the self configure for X-Arcade in the GUI did (on screen) match the X-Arcade default.....but when you actually used the X-Arcade the buttons didn't work properly. For those of you not familiar w/Zinc the GUI is pretty similar to MAME and has a button to click on that configures it to work with Hot Rod and X-Arcade.
In case anyone is interested in trying Zinc out , here are the links to the pieces you need:
GUI:
ZINC HOW TO GUIDE:
http://www.mameworld.net/easyemu/zincguide.htm
ZINC ROMS:
link deleted...don't link to ROM sites.
Thanks for all of the advice guys!
One last question.....if anyone knows of a more up to date GUI that supports the more recent games like Mr. Driller....could you post the link? Thanks!!!
The MameMaster
(and now the Zinc apprentice)
« Last Edit: October 04, 2008, 07:39:56 am by Peale »
gfunk2k
  • Last login:September 07, 2009, 08:15:00 pm
« Reply #7 on: September 23, 2008, 01:09:15 pm »
;D SUCCESS!  ;D
GUI:
ZINC HOW TO GUIDE:
ZINC ROMS:
The MameMaster
how did you remap the xarcade buttons?
« Last Edit: October 04, 2008, 08:28:01 am by saint »
MameMaster!
    • Mame Invaders!
Re: ZiNc Question/X-Arcade
« Reply #8 on: September 24, 2008, 09:21:07 am »
Go to the XArcade site (if you don't have the instructions that came w/the XArcade). You can remap the buttons via a program switch on the back of the XArcade.
(wow, you resurrected my thread from 5 years ago!!---  :applaud:)
