Author Topic: U360 pin-out?  (Read 1757 times)
fytr
  • Last login:May 07, 2021, 10:39:46 am
U360 pin-out?
« on: April 24, 2010, 12:22:48 pm »
Hi,
I'm making my own wiring harness for my U360s to connect buttons to. In the U360 docs that Andy/Ultimarc provides for the U360, they don't provide the actual pin-out diagram for the 10-pin input/output header on the joystick. I guess he'd rather sell his wiring harnesses for that or something.
Has anyone mapped the pin-out on the U360 already or know where to find it? This would save me some time figuring it out by trial and error, etc.
Regards,
  Ken
dgame
  • I am no Jedi
Re: U360 pin-out?
« Reply #1 on: April 24, 2010, 12:33:09 pm »
You could be less accusatory in your request for help.
See: Use of the 10-pin I/O port (Optional)
Here: http://www.ultimarc.com/ultrastik_inst.html
fytr
Re: U360 pin-out?
« Reply #2 on: April 24, 2010, 01:18:24 pm »
Thanks for the response. I don't mean to be negative on Andy, he's great! But after spending a large wad of $$$ on these awesome joysticks, I figured I could save a few bucks and make the wiring harnesses myself. With all the "necessary" optional items I've already paid for (springs, restrictors), it really $5 and $10 you death.
I am aware of the link you provided, but it does not show the pin-out on the u360 board, just the color-coding for the optional wiring harness that Ultimarc sells. I guess I should ask Andy for it.
Thx.
  Ken
dgame
  • I am no Jedi
Re: U360 pin-out?
« Reply #3 on: April 25, 2010, 11:52:22 am »
Code: [Select]
With the connector pins being:
X1234
56789
X = blocked/unused/no pin
Pin Wire   Input Mode   Output Mode
5 = Black COM Connect to COM terminals on all buttons GND. Connect to I-PAC if required
1 = Brown Button 1 NO not used
8 = Blue Button 2 NO Down Digital. Connect to I-PAC if required
2 = Orange Button 3 NO Right Digital. Connect to I-PAC if required
7 = Yellow Button 4 NO Left Digital. Connect to I-PAC if required
3 = Green Button 5 NO Up Digital. Connect to I-PAC if required
6 = Red Button 6 NO 5 Volt supply. Not required if USB is connected
9 = Grey Button 7 NO Raw analog. Not used at present
4 = Violet Button 8 NO Raw analog. Not used at presentt
fytr
Re: U360 pin-out?
« Reply #4 on: April 25, 2010, 07:51:01 pm »
Thanks for the reply.
I asked Andy about it yesterday and he's now updated the U360 installation page with the pin-out in addition to the harness wire colors, including a handy diagram of the connector.
Andy is just fantastic, where else can you get that kind of turn-around on a weekend. :)
Hopefully this information will prove useful to others in the future.
Regards,
  Ken
