Author Topic: speakers not getting power?  (Read 2093 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: April 18, 2010, 06:17:31 pm »
For my jukebox that is nearly finished i ripped apart a set of computer speakers for the amp. When plugged in it powers up, so i chopped the plug off, wired an inline mini 3A fuse and plug it in, nothing - dead. however both my PC and monitor (using 10A) work fine using the same method, what have I missed? i can't see any logical answer for this, i've checked the fuse with a multimeter, however don't feel like sticking the probes in a mains electric circuit whilst its on.
any tips would be great thanks
BobA
  • What Me Worry?
Re: speakers not getting power?
« Reply #1 on: April 18, 2010, 06:19:41 pm »
Check the continuity of you mains power.   It sounds like the speaker amp is not getting power.
david656
  • Big Man!
« Reply #2 on: April 18, 2010, 06:24:20 pm »
how would i do this? set the multimeter to the fuse setting... turn the circuit off.. have one end on the plug and one at the other side of the fuse? I will do this again but i'm pretty sure i did that yesterday.
One other thing i have noticed is sometimes the PC won't power... but you unplug it and replug it maybe hit it and it will power up. the fuse holders are soldered in so i find that a little odd.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: April 20, 2010, 04:53:20 pm »
Was this a regular power cord (AC) or was this the cord from something like a wall wart (DC) ? If it was a wall wart, then maybe the polarity is backwards. (+ - )
