Author Topic: Track Ball Woes and a Quickie  (Read 1386 times)
TalkingOctopus
    • My Arcade
« on: July 29, 2003, 08:24:03 pm »
Hey All,
I have a 3" happ trackball connected to a Hagstrom ke72-t with the hagstrom cable.
My problem:
When I spin the tb left, the cursors goes right.  Right = left.  Up and down are normal.  This is in windows xp.  I have the tb oriented correctly, (The monitor arrow faces the monitor).
Do I need to hack up the cable and pull a switcharoo?  Did anyone else have this problem and have a solution? Am I just wrong?  It has been a very long time since i have used a trackball, but this just cannot be right
My Quickie:
On a happ over under coindoor, do I attach the red 5v or the yellow 12 v wire from the computer power supply to the lights that came with the door.  I know either would work, but which would work best?  I was thinking 12 v.
Thanks in advance!
OSCAR
    • Oscar Controls
Re:Track Ball Woes and a Quickie
« Reply #1 on: July 29, 2003, 10:08:49 pm »
Does the KE72-T have a "reverse direction" jumper like the ME4 does?  If so, that would be the easy way.  If not, all you need to do is swap the yellow/green wires going into the trackball Molex connector.
The yellow 12V is what you would use for coin door lights, wired in parallel.
Raleigh
  • Bean Counter
  • Last login:August 04, 2025, 01:30:01 pm
  • 1-2-3 Kick, 1-2-3 Kick...
« Reply #2 on: July 29, 2003, 10:28:46 pm »
I've got the KE-USB36 which has the trackball interface like the KE72T and in the hagstrom program where you program the inputs is the trackball controls where you can reverse the axis.
« Last Edit: September 02, 2011, 11:08:37 am by Raleigh »
TalkingOctopus
    • My Arcade
« Reply #3 on: July 30, 2003, 12:46:08 am »
Whoa that config is really nice...The one with the ke72 must be run in a dos prompt and uses a text file.
I will have to check on that jumper...but I don't think it exists.  I will cross those 2 wires.  Thanks for your help!
TalkingOctopus
    • My Arcade
« Reply #4 on: July 30, 2003, 12:50:56 am »
Opps....Its actually better than a jumper. A command!
Trackball X Direction Reversal -  The reported direction of the X axis
                        of the trackball input in the model KE72-T may
                        be reversed using the following command.
REVX:Y
This option, when set, will reverse the direction of the X axis data
when reported to the PS2 mouse port.  Use this option if the left-right
movement of your trackball device operates in reverse to the default
direction.
Note that not specifying a setting for this option is the same as
stating the option as REVX:N
