Author Topic: zener diodes  (Read 1919 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
zener diodes
« on: April 14, 2010, 09:22:06 am »
Can anyone tell me? Is there a way to test (check) a Zener diode??
In theory, there is no difference between theory and practice, but in practice.....there is!!
MonMotha
Re: zener diodes
« Reply #1 on: April 14, 2010, 09:41:42 am »
The "diode check" setting on most digital meters can usually be used.  Should read ~0.7V with the red lead on the anode and black lead on the cathode, and it should read approximately the rated zener voltage (maybe a little lower) the other way.
kardenm
Re: zener diodes
« Reply #2 on: April 14, 2010, 09:53:08 am »
Thanks. How can I tell what the rated zener voltage should be? Which end is cathode or anode?  Mine tests 0.00 volts in both direction on the diode check setting.  I guess that means it is bad??
kardenm
Re: zener diodes
« Reply #3 on: April 14, 2010, 10:02:38 am »
It's a "7.5BM" (from schematic), a 7.5v zener diode. I guess that means it should reab 7.5v in the other direction.?
MonMotha
Re: zener diodes
« Reply #4 on: April 14, 2010, 10:04:59 am »
Zener voltage rating is the primary rating of the part.  "7.5BM" sounds like probably a 7.5V zener, yes.  The end with the stripe is the cathode.
If you're reading 0V in both directions, it's probably failed shorted.
kardenm
Re: zener diodes
« Reply #5 on: April 14, 2010, 10:11:44 am »
Thank you MonMotha.
