Author Topic: u360 buttons sticking - FIXED  (Read 1409 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« on: April 13, 2010, 07:14:48 pm »
I've noticed for a while that my gaming skills seemed "off" after I got my new control panel rigged up.  Turns out there is something funky going on with my u360s.  My buttons are attached to the u360 via the wiring harness.  I found in Windows controllers window if I hit a joystick direction and button at the same time the button will continue to register as "pressed" (even after released) until I release the joystick.  I tried using a button wired to a separate hacked controller in combination with the u360 and everything worked peachy.  Anybody else experiencing this?  Andy?!?
EDIT--- Turns out it was my 4-way map causing all the problems.  I replaced all the cells that had "stickies" with cells that had arrows and things work fantastic now.
« Last Edit: April 13, 2010, 10:16:16 pm by KonkeyKong »
