Poll
is it possible to bypass coin insert to play songs
yes
0 (0%)
no
1 (100%)
Total Members Voted: 1
Author Topic: ami r85 jukebox  (Read 4520 times)
satisfair
  • Last login:April 20, 2010, 07:35:15 pm
ami r85 jukebox
« on: April 13, 2010, 12:11:26 pm »
is it possible to by pass coin insert toplay selections
Ken Layton
  • Guru
  • Technician
Re: ami r85 jukebox
« Reply #1 on: April 13, 2010, 01:45:27 pm »
On the Central Control Computer, there is a slide switch labeled "TEST-NORM". Slide it to "TEST". Machine is now on free play.
To take it off of free play simply slide the switch back to "NORM" position.
satisfair
Re: ami r85 jukebox
« Reply #2 on: April 13, 2010, 03:33:55 pm »
this should allow me to choose the record or it plays what it want's
Ken Layton
  • Guru
  • Technician
Re: ami r85 jukebox
« Reply #3 on: April 13, 2010, 10:52:06 pm »
Yes you can select what you want.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: ami r85 jukebox
« Reply #4 on: April 14, 2010, 04:48:35 am »
Hi Satisfair,
Ken is correct re the Test/Normal switch when on test gives free play.
I would switch the Playmaker Mode switch to off that way your selections will not be interrupted by the playing of a random B side record ( this mode should only come into operation if a selection had not been made by the keyboard with the setting defined by the playmaker mode) this feature was used in sites to get the customers to play some descent music.
If your CCC has the Order of Play switch on site it would have been set to STD rather than As Selected to cut down the down time of scanning the mechanism (carousel) to find each record as it was selected.
This CCC was used on the R-84 through to the R-88 and included the RI-3 to RI-5 and CTI-2.
Regards
Alan Hood
ami-man
UK
satisfair
Re: ami r85 jukebox
« Reply #5 on: April 15, 2010, 05:38:10 pm »
juke box working great appreciate the help guys,in past and pressant
now i just have to find the plastic #'s that go on the rack and all is cool
ami-man
Re: ami r85 jukebox
« Reply #6 on: April 16, 2010, 05:18:42 am »
Hi satisfair,
Are you talking about the plastic numbers that go onto the wire dividers of the mechanism. If that is the case they are called Belt Guide Rowe Ami part number 4-0702-01.
They are available at Suzo Happ, more than likely Victory Glass or in the uk at www.jukeboxparts.co.uk or myself.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
