Author Topic: Hanging the mameroom jukebox  (Read 4259 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: April 08, 2010, 02:15:18 pm »
Hanging the mameroom jukebox anyone have any ideas on hanging this to the wall.
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
Re: Hanging the mameroom jukebox
« Reply #1 on: April 08, 2010, 05:08:41 pm »
Depends on weight of the jukebox. I would definately make sure wall studs are used for anything over 6lbs vs. using just platic drywall anchors.
How 'bout some pics of the jukebox as well  ;)
Fordman
WhereEaglesDare
    • My HomePage
« Reply #2 on: April 09, 2010, 08:35:50 pm »
If it is over 6 pounds use Lag Bolts in to Studs.  Make sure that is it studs if you arent sure try in dry wall only to get a feel for it, then try where you think the stud is and it should be much tougher to drill it in then it was.
kjbalto
  • Last login:January 20, 2018, 12:33:06 pm
« Reply #3 on: June 16, 2010, 07:43:11 pm »
I bought two L brackes that I bolted into the studs on my wall.  This was for the bottom of the jukebox to sit on.  Then for the top part, I put two latches on top of the jukebox.  This way the jukebox can come on and off the wall in literally 5 seconds.  I sit it on the L brackets and close the latches and turn them so it locks. I can send you a pic if you want to see.
divemaster127
« Reply #4 on: June 16, 2010, 08:03:31 pm »
that would be great if you could post pics
thanks
dm
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #5 on: June 28, 2010, 12:39:37 pm »
For my jukebox, which isn't the mameroom wall juke but it is very similar, I used a french cleat.
Instructions here:
http://www.newwoodworker.com/frenchcleat.html
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #6 on: July 09, 2010, 07:35:46 pm »
Here's another link to french cleat concept...
http://benchmark.20m.com/plans/FrenchCleat.pdf
« Reply #7 on: July 16, 2010, 10:57:19 pm »
French cleats are great! I hung a dartboard ( and cork surround) using that technique.
In fact, I believe I used 2 aluminum door thresholds as the cleats, Easy to screw on, very low profile, they "hook together" perfectly and they're metal!
