Author Topic: RESOLVED Mobo front panel connector wires: where can you get the terminators?  (Read 1452 times)
Diewrecked
  • Last login:June 20, 2012, 07:34:08 am
Hi guys
I'm not sure how to describe this but I'll have a go!
You know on the front panel connectors from your PC case each wire is terminated with a little square block with a label on it (eg power switch +, power switch -, HDD light +, reset switch - etc) - what are those little blocks called and where do you get them from (in the UK) please? I want to get a couple to connect to the cables going to my power switch (which is a button on my CP rather than the power switch on my PC case) but I don't even know what to search for!
Many TIA
Cheers
« Last Edit: April 07, 2010, 06:43:54 am by Diewrecked »
Diewrecked
It's ok I've resolved this. I took the fascia off the front of the case and snipped the two wires going to the power button, then just wired them up to my Cherry switch underneath what will become the power button.
Nice and easy :)
Cheers all
Franco B
Just for future reference:
JST Cables (10-Pair) - $2.98 with free worldwide shipping from dealextreme.com
Click the image for the link.
If I had seen your post yesterday I could have sent you one (I'm in the UK too) for free.
At least you have it sorted  :cheers:
