Author Topic: Help needed with SFIV Controls in arcade cabinet  (Read 2089 times)
cleetus
  • Last login:August 15, 2010, 12:19:37 pm
« on: April 05, 2010, 07:51:42 am »
Hello everyone,
I am a long time lurker but first time poster.
I recently installed SFIV pc version on my SFII CE / MAME Cabinet using Ultimarc's latest PCI Expresss video card. It proved to be a very difficult task setting it up but I got it to work non the less. The only thing I don't like (that's where my question comes in) is there a way to use the control panel stick and buttons on the cab to control all the menus in the game and by that I mean that as it stands, I have to use the keyboard to navigate the menus and character select screen and once the fight starts, I am able to use the stick buttons on the control panel. Very annoying to say the least.
Any help or guidance would be greatly appreciate it.
Cheers guys :)
cleetus
Re: Help needed with SFIV Controls in arcade cabinet
« Reply #1 on: April 05, 2010, 05:36:38 pm »
Anyone?
massive88
cleetus
« Reply #3 on: April 05, 2010, 06:00:33 pm »
Thank you for the reply and link, however I have tried that method and I still have the same problem.
Not sure what I am doing wrong though. My control panel buttons are all conncected to an xarcade pcb, so when I was editing the 360.ini file, I used the Xarcade sample file listed on the link but it does not work, unfortunately.
« Last Edit: April 05, 2010, 06:02:54 pm by cleetus »
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
« Reply #4 on: April 05, 2010, 06:26:03 pm »
In my SFIV if the first button detected is from a keyboard, the menus will be affected to the keyboard. So try to never touch any keyboard keys , and use only gamepad keys. The menus should be controled with your joystick/pad.
I personnaly use 2 hacked gamepad and not the "keyboard hack", but i hope it will help.
« Last Edit: April 05, 2010, 06:27:41 pm by ptinolv »
massive88
« Reply #5 on: April 06, 2010, 10:55:17 am »
Dunno what else to tell you except to re-read all the instructions and make sure you followed them to the letter.
I used the method described to get my Ipac hook up to work, but theoretically it should work for any keyboard encoder the exact same way.
cleetus
« Reply #6 on: April 06, 2010, 04:03:11 pm »
I'm such a tool. After comparing files, I noticed I was off by one digit, hence as to why it wouldnt work.
Fixed it and all works well now :)
Thanks everyone for their help.
bobic
  • Last login:May 27, 2010, 12:28:50 am
« Reply #7 on: May 26, 2010, 09:31:12 pm »
yes you are a tool.
