Author Topic: can someone explain what I'm doing wrong in future pinball?  (Read 2792 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: April 02, 2010, 08:51:40 pm »
I can always get the tables to load.. but never ever to play.  I have insert coin 1, 2, and 3 to 5, i have start game set to 1, I hafe left flipper set to A and right flipper to right shift.
But when I start the table nothing happens.  I press "5" over and over and "1" and nothing happens.  I can nudge it with the space bar, but other than that it never seems to work.  Anyone willing to help?
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
Re: can someone explain what I'm doing wrong in future pinball?
« Reply #1 on: April 02, 2010, 10:27:07 pm »
Try one of the following:
1. Click the left mouse button (makes fp active)
2. Alt-Tab
shateredsoul
« Reply #2 on: April 03, 2010, 12:34:38 am »
didn't work..
Should I be hearing sounds when I start the tables? I don't hear anything.. no music or sound effects
nudging the table and changing the points of views work .. not sure why I can't get the coin, start, and plunger to respond
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: April 03, 2010, 01:01:39 am »
What OS are you running?  If you are running Win 7 or Vista make sure that you run FP with Admin rights.
shateredsoul
« Reply #4 on: April 03, 2010, 04:10:50 am »
Ahh running with administrator rights did the trick.. :applaud:
I'm using windows 7.
Now to figure out Visual Pinball
