Author Topic: Drilling holes in laminate  (Read 1465 times)
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« on: July 28, 2003, 09:50:53 pm »
I used a spade bit to drill the wholes in my control panel top and just layed the laminate on top.
I tried using the same spade bit to drill a whole in the laminate, but it chops it all up.
What should I use?
Thanks! :)
SlikStik-Christian
  • Last login:November 04, 2004, 10:28:08 pm
  • Gaming will never be the same...
    • SlikStik Arcade Controllers
Re:Drilling holes in laminate
« Reply #1 on: July 28, 2003, 10:03:51 pm »
Turn your panel over (Make sure you don't have anything on the table that will scratch the formica) and drill 1/2" holes in the center of your 1 1/8" holes, then flip it back over and use your router with laminate trimming bit to make the actual hole, the 1/2" hole should let you pop your bit right through. Also make sure your router is clean before you do it so you dont scratch the laminate.
« Last Edit: July 28, 2003, 10:06:12 pm by SlikStik-Christian »
Thank You
Christian
SlikStik Customer Support
http://www.slikstik.com
The Worlds Best Arcade Controllers
SNAAAKE
  • -Banned-
« Reply #2 on: July 28, 2003, 11:36:21 pm »
umm...?
how about the laminate your panel FIRST then drill with spade bit.
I have done it many times before..worked.
« Last Edit: July 29, 2003, 02:31:13 am by SNAAAKE »
