Author Topic: FS in NJ - Unique cab - Ladybug/Frogger  (Read 5099 times)
Rick Osborn
« on: May 30, 2002, 07:40:07 am »
Check out the pictures by following the link (512k pic collage).
http://members.aol.com/arcadepics2/ladybug.jpg
This is a unique cabinet that currently is setup to play Frogger.  The power supply isn't working correctly now so the game itself does not play.  The monitor works fine and the cabinet is a BEAUTY!  Check out the curves and styling.
At one point in it's life this was obviously a Ladybug.  But it was also a Scramble early on too because the wiring harness it still inside and labeled.
This cab would make a very nice MAME machine and you could either use the existing arcade monitor or easily fit a TV or PC monitor inside.
As you can see, the cabinet is VERY clean and in GREAT condition.  The control panel is not metal, but is a lighter plastic that is a little thicker than bezel plastic it seems.  So you could modify the control panel for additional buttons and controls or remove it and install your own.
This is available for pickup in Howell, NJ for $200 or best offer.
Thanks,
jee park
Re: FS in NJ - Unique cab - Ladybug/Frogger
« Reply #1 on: June 01, 2002, 10:30:25 pm »
i'll give you $75 and you can keep everything inside. I just want the cabinet. im also in nj. email me for my number. or email me yours.
