Author Topic: Mamewah Snap renaming feature  (Read 2016 times)
TheGameAh
  • Last login:June 09, 2004, 10:52:01 am
  • You are not FreakZilla.
    • Arcade Cab
« on: July 28, 2003, 09:10:27 am »
Hey guys.  I know this has been talked about before, but how do you get this feature working in the new version of Mamewah?  I'm taking snapshots through emulators running through Mamewah, but they aren't renaming the snaps.
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
Re:Mamewah Snap renaming feature
« Reply #1 on: July 28, 2003, 10:37:28 am »
I have not tried this in the new version (v954b), but i had it working in v952b.  What you need to do is know where the EMU is putting the snap when you take it.  From their you have to put that path and file name in the CGF file for that EMU.  IE  PJ64 creates a file called snap0000.bmp, so in the CFG file where it says "Replace Artwork..." then enter this
(what ever your path is, some EMUs let you change the output DIR of the snaps too)
Then once you take a snap in the emu (given the emu was launched from MW) it will rename the snap when you exit the EMU (also i have noticed you have to scroll off the game and the come back to see the new snap).  Also some EMUs incrament the number, so it goes Snap0000.bmp , Snap0001.bmp...  If it is dumping a different file name then MW can't rename!  Check to make sure you don't have a snap sitting in the Snap output DIR forcing the incrament.
Does this make sense?  Instant Message me if you need further help / clearification.
TheGameAh
    • Arcade Cab
« Reply #2 on: July 28, 2003, 11:06:13 am »
Ah, thanks a lot.  That's probably why I can't get it working.  All the emus I use name the snap as a unique name, the the rom name followed by some weird characters or something.  Mamewah probably can't handle renaming them then.
Unkis17
« Reply #3 on: July 28, 2003, 12:46:23 pm »
what emu's are you running.  You can use the '?' as a boolean type character!  I use this in Gnes...
« Reply #4 on: July 28, 2003, 01:44:54 pm »
Unkis17 is right, for emus that generate say 'Sonic The Hedgehog001.bmp', you would use the ? wildcard and enter '?001.bmp' (OK so I forgot the path, but you get the idea)...
